YAMAHA C4 phono capacitance
Discussion in 'Yamaha' started by Edu1985, Mar 20, 2017.
  1. Edu1985
    Edu1985 New Member
    35
    Hello everybody!i recently purchased a Yamaha c4 which I love for it s phono section but I have encountered a little problem:when switching the capacitance loading I can t hear any modification in the sound.the kohm loading works perfectly but in the capacitance i can t tell any difference at all .I m using it with a audio tehnica at 91e.it could be the cartridge to blaim?i had another c4 a few years ago and used it with nagaoka and shure cartridges and i renemeber that the capacitance was making differences in sound but with this yamaha...nothing in the capacitance department.so ..any ideas?I 've checked the board for bad solder and cleaned all switches with contact cleaner.could it be from somewhere else the problem in capacitance?
  2. avionic
    40,666
    Fort Dodge, Iowa
    Did you disassemble the load switches ? If not, there not clean.
    Edu1985 likes this.
  3. avionic
    40,666
    Fort Dodge, Iowa
    Almost impossible to get clean without disassembly.
    Edu1985 likes this.
  4. Edu1985
    Edu1985 New Member
    35
    Thanks for the reply,Avionic.no,I did not disassembled the loading switch.it looks like a lot of work to do this.maybe i could do this without desoldering the switch from the board.hmmm
  5. avionic
    40,666
    Fort Dodge, Iowa
    Sorry Charlie.. Thats a fantasy. The switch needs to be removed and disassembled.
    Edu1985 likes this.
  6. Edu1985
    Edu1985 New Member
    35
    Aside from the switch being dirty could it be something else?
  7. avionic
    40,666
    Fort Dodge, Iowa
    The switch would be my primary suspect.
  8. avionic
    40,666
    Fort Dodge, Iowa
  9. avionic
    40,666
    Fort Dodge, Iowa
    Also post #147...
    Edu1985 likes this.
  10. Edu1985
    Edu1985 New Member
    35
    I understand...I will see what can I do.the rest of the switches and pots work very good.
  11. Edu1985
    Edu1985 New Member
    35
    I have checked the switch without taking it down the board with the multimeter on beep function and it beeps on all the settings in both chanells.So the switch looks good.if the other switches were making same problems it could be the switch but all others work well so it could not be an isolated case.any ideas what to check next?
  12. Edu1985
    Edu1985 New Member
    35
    Solved!i redid the solder points of the switch.now works perfectly!
  13. avionic
    40,666
    Fort Dodge, Iowa
    Got lucky..
  14. Edu1985
    Edu1985 New Member
    35
    Yepp...so happy...listening to vinyl.i will have to replace all caps in the near future.
  15. Mr. Yamaha
    Mr. Yamaha Not so much Yamaha lately... Subscriber
    857
    Amsterdam Area, The Netherlands
    I won't replace all caps if I were you, just the lytics :thumbsup:
  16. Edu1985
    Edu1985 New Member
    35
    Yes ,to the electrolytics i was reffering.but for now it sounds pretty darn good for almost 40 years old!
