soulstreamerAK
I have the above and need a pilot lamp which is driven off a 33vac supply, although the manual says the lamp should be 14.5 volt, 80ma. any ideas where to get or obstacles I may encounter.
also, the volume pot needs cleaning and I dont know how to get access to the innards. It has 2 small phillips screws on the end, but they dont help much. I tried dowsing the pot with cleaner and it helped, still needs more. If I can't clean it enough, it says 50k x2 and 10k x2. Can it be replaced?
