vibroverbus
Hack of All Trades
Just started to poke around on a busted CA-1010, in which relays don't seem to click on properly. Have read previous posts suggesting common failure modes for this one including:
Haven't attended to all of those yet... I certainly will, but there's another question bothering me - running it on the trusty variac (always on the bench if only for the ammeter to keep an eye on currrent draw for un-trusted pieces). It seems this unit draws a lot of current all the time, even if it's not in "Class A" mode (and yes I know what Class A is). Flipping the mode switch doesn't cause a noticable change in the current draw although seems like a slightly different sequence of clicking noises comes from the relays.
I would have expected the high draw in Class A but for it to drop considerably in AB mode. Specifically it is pulling something around 1.5-1.8amps with switch in either position (and no input signal applied). From a quick look, basic PS voltages seem essentially correct. Haven't dug much further yet.
Can anyone suggest what 'correct' current draw would be to expect on this unit? Is there a known failure for them getting stuck in Class A (aka switch or the related relay)? No DC on outputs by the way, that's always my first check before allowing anything to come near speakers...
- Relays
- Solder joints
- Dirty switches & pots in various places
