I just had the opportunity to buy this great Yamaha amp CA-2010 from a guy who said that something had blown and all went dead. Furthermore, he told me that the meters had stopped working some years ago. Cosmetically, it is almost perfect, so I thought that it was worth the 100 bucks he asked and took it with me.
At home, I disassembled the amp to check what might be broken or defective, but so far, I found nothing. All fuses are ok, all output transistors test ok, the rectifier diodes as well as the filter caps also seem to be all right. I'm going to clean it and switch it on behind a lamp to see if the reported problem is more complicated or simply was some kind of the guy's confusion.
However, regarding the meters, I'm confronted with the worst case scenario. Someone had the bright idea to remove the proprietary Yamaha PM-02 resp. IG 00136 meter driver. It is simply entirely missing. Not there anymore and most certainly carelessly thrown away like a burned out lightbulb. Searches on the internet and especially in Ebay didn't show any results for spare parts, it seems to be impossible to find a replacement. My only remaining hope right now is to rebuild it. In a Japanese Yahoo blog, I found a thread from a guy who opened the case of the driver to repair its internals:
One can see that only quite ordinary parts are used inside the driver, and the Japanese guy seems to have managed to repair his defective item. Not surprising, given that all visible part should still be easily available today.
Unfortunately, I'm not capable to reconstruct the driver from the image, and worst of all, there are not the slightest details contained on it in the CA-2010's service manual.
So my question is: Does anybody happen to have more detailed information about it? Perhaps even the schematics? I checked the ones of the meter board that's inside the CA-1010, but there are some major differences around it that most likely make it impossible to just copy that one.
Thanks in advance for any hints!
Thomas
Thomas
