Bluhn321
Hockey: Making dentists rich since 1875
Hi everyone,
I have a Yamaha Ca-2010 that has an issue. When you first turn it on with the volume at zero both relays click on and it seems okay. However as soon as you turn the volume up both relays start to click on and off. One strange thing I noticed, if its any help, that if you turn off the pre-out under the audio muting switch both relays will click on and stay on if you turn up the volume.
When its stable with the volume at zero I measured DC output and both channels only had a few mV so the amp section seems fine.
UPDATE-
The relays will click when powered no matter what volume or setting. I also notice that the power relay has an arc each time it clicks so something is drawing current.
Any help would be greatly appreciated!
UPDATE-
