Yamaha CA 401
Discussion in 'Yamaha' started by bond.70, Oct 12, 2018.
  1. bond.70
    bond.70 Member
    77
    Bought for 42€ few days ago, good overall conditions, connected to my ipod then to Sennheiser Momentum headphones, really disappointed, the sound was flat, without bass, Phil Collins seemed a ghost!...with headphones directly to ipod the sound is big, full of details, crispy and Collins is so real and present!...not only the amp was not able to give me more audio level but it was able to ruin completely the sound!
  2. avionic
    46,508
    Fort Dodge, Iowa
    CA-410 perhaps? Bad tantalum caps in the tone circuit.Probably a few electrolytic capacitors past their prime.As well as drifted fusible resistors. Check the idle current/bias.
  3. avionic
    46,508
    Fort Dodge, Iowa
    Not to mention dirty switches and controls.
  4. bond.70
    bond.70 Member
    77
    330F4874-F7EF-4429-A232-39D561DD39C4.jpeg B837FB9C-3268-47B3-A2D0-7CD731750C18.jpeg 31E59B64-81EC-4721-AFD3-53837CDEC1DC.jpeg
    avionic likes this.
  5. bond.70
    bond.70 Member
    77
    Hi yes sorry CA-410
  6. avionic
    46,508
    Fort Dodge, Iowa
    Looks in pretty good shape..
  7. bond.70
    bond.70 Member
    77
    Yes it has only two tiny almost invisible marks around the input selector and one small chip on the wood were I will put a bit of wood putty to fill the imperfection...but as you said I have to check inside and I'm quite sure it needs a full recap!
  8. bond.70
    bond.70 Member
    77
    Opened it and found one of the two big 4700uf caps a bit swallen on top...
    All the other caps are Nichicon some tantalum caps around...
  9. amr2
    amr2 Well-Known Member
    581
    I would do a full recap. I’m sure it will sound very good once revisted.
  10. bond.70
    bond.70 Member
    77
    first I would put a couple of Nichicon 6800uf 63V in place of the old 4700uf 40V then to follow all the others electrolytics they are Nichicon as well but 40 years old, but what about the tantalums? the tone control board is full of them for example...
  11. amr2
    581
    Personally I don’t like tantalums, they have tendency to create short circuit failures. Depending on the position in the circuit, I usually change them with film or Low Leakage (UKL).
  12. amr2
    581
    But you can leave the tantalums alone
  13. avionic
    46,508
    Fort Dodge, Iowa
    Get rid of the tantalums..Especially in the tone board.
  14. amr2
    581
    It's what I would do :thumbsup:
    avionic likes this.
  15. bond.70
    bond.70 Member
    77
    What about Wima MKS II in place of tantalums?...
  16. avionic
    46,508
    Fort Dodge, Iowa
    Sure.. 1uf/35v tants.I believe. They remind me of clown fish for some reason.
  17. bond.70
    bond.70 Member
    77
    Have to read all the values convert them and make a list...
  18. bond.70
    bond.70 Member
    77
    Could someone help me to understand the tantalums values?...
  19. mbz
    mbz Super Member
    2,447
    Melbourne, Victoria
  20. avionic
    46,508
    Fort Dodge, Iowa
    Look over the parts list and the schematic in the service manual.
