This unit is particularly infamous for literary frying the circuit boards of the power supply section.
Besides a few parts in there that would need replacement indeed, it is 90% likely that the boards are beyond repair by an average repair shop (more likely to do a severe bad repair, probably causing even more trouble later).
I am currently rebuilding (mechanically reconstruction actually) one of those burned out CR-2020 boards, and it involves epoxy repair, special rivets and then rebuilding the thing in a way that the problem won't happen easily again. It takes many manhours, and quite some skills and special tools.
If the repair shop quotes $50 in parts, then they are probably thinking of replacing the four troublesome resistors as per special CR-2020 service bulletin ($20 in parts / $30 in labour).
The thing is that the these resistors burn serious holes inside the board, something which becomes only visible when the board is removed (you can't see it when assembled).
So there is a big risk that the shop will call you halfway the job, quoting either a lot of extra hours or stating unrepairable.
Worse case they try something quick and ugly and tell you nothing.....
Yes, it is repairable, but you need to find somebody who knows about this particular unit and who does the right kind of repairs.....
In some weeks time I will post my repair journey.
And it has been a journey.....
If I was a commercial repair shop, the manhour count would be in the $500 zone
