Yamaha CR 2040 power transformer
Discussion in 'Yamaha' started by SFSGTR, Nov 5, 2018.
  1. SFSGTR
    SFSGTR New Member
    10
    I've been the losing bidder on several "for parts only" 2040s, and I am in search of a power transformer for this model. Is there any source (vendor, manufacturer) who might have this transformer?
    Thanks!
  2. avionic
    45,543
    Fort Dodge, Iowa
    try ebay
  3. avionic
    45,543
    Fort Dodge, Iowa
    What makes you think its bad? Is it missing in action MIA ?
  4. avionic
    45,543
    Fort Dodge, Iowa
    If its not missing. And the primary is "open". It may be repairable. There is a fusible link within the transformer.
  5. SFSGTR
    SFSGTR New Member
    10
    I found a donor unit. Anything else I should have double checked when the power transformer is installed?
  6. avionic
    45,543
    Fort Dodge, Iowa
    Is the primary and secondary windings showing continuity?
  7. clinic-audio
    2,271
    France
    Is your donor unit 100% identical to your model ? Some have specific power transformers
    GA62620 USA Model
    GA62630 Nord European Model
    GA62640 General model
    GA62650 Australian and British Model
    The thermal fuse is there :
  8. SFSGTR
    SFSGTR New Member
    10
    Same model; donor unit powers up fine, though no sound.
  9. clinic-audio
    2,271
    France
    DC protection actived ?
    Any sound coming from" record " output sockets ?
  10. SFSGTR
    SFSGTR New Member
    10
    Haven't tested that yet, but it does power up ok.
  11. SFSGTR
    SFSGTR New Member
    10
    What are the amp / watt ratings for the three fuses in the 2040?
  12. avionic
    45,543
    Fort Dodge, Iowa
    Two 3A and one 10A fast blows.. They should be labeled somewhere close to the fuses.
  13. avionic
    45,543
    Fort Dodge, Iowa
    That eliminates the 10A fuse.Does the relay "click" once shortly after power up?
  14. avionic
    45,543
    Fort Dodge, Iowa
    Lamps or red LED's illuminate? Any movement in the meters?
  15. SFSGTR
    SFSGTR New Member
    10
    Tech said that since smoke came out of the back of the unit when I powered it up, there were probably more issues beyond the power transformer. Since the donor unit has a good transformer, but with no sound, perhaps the donor unit can be repaired. My original 2040 was said to be defunct, but has excellent cosmetics. We shall see...or hear.
    Thanks for all the responses and suggestions!
    b
