Yamaha CR-600 Offset Issue
Discussion in 'Yamaha' started by ivandezande, Oct 21, 2018.
  1. ivandezande
    ivandezande Super Member
    1,941
    Twin Cities
    I think I'm cursed from working on CR's, second one with strange issues. This guy had a blown bridge rectifier and everything else seemed to be fine.
    On the driver board I replaced the caps, the bias transistors Q707,8, Q705,6 as they were Sony's that I've had problem with, and trimmers.
    It biases perfectly, but when I measure for offset between test points, it looks to be almost negative 30V on each output! I checked for transistor installation, but 7 and 8 are fine if the SM is right and it biases so not worried about 5,6 and they are supposedly in correctly.
    I'm seeing -37V on the collectors of 707,8 which should be -1V. Emitters are -27V and -37 respectively. Bases are correct at 37V.
    On the input pair, I'm seeing 37V on both collectors which isn't right.
  2. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,297
    Fort Dodge, Iowa
    Check F801.
  3. ivandezande
    1,941
    Twin Cities
    Looks ok at 4.4 ohms.
  4. avionic
    46,297
    Fort Dodge, Iowa
    Are you seeing +37.5vdc at the fuse?
  5. ivandezande
    1,941
    Twin Cities
    Like the fuse resistor? 21.5V there. Seeing 38V on the main fused rails.
  6. avionic
    46,297
    Fort Dodge, Iowa
  7. avionic
    46,297
    Fort Dodge, Iowa
    What test points? TP-3 and TP-5?
  8. ivandezande
    1,941
    Twin Cities
    Yup! And 1 & 3.
  9. avionic
    46,297
    Fort Dodge, Iowa
    1 & 3 / 2 & 4 are bias TP's.
    3 & 5 / 4 & 6 are offset TP's
  10. ivandezande
    1,941
    Twin Cities
    My bad, I did mean 3,5 4,6. Looked at the SM again too fast.
    Bias sets fine reading from 1,3 and 2,4.
  11. avionic
    46,297
    Fort Dodge, Iowa
    So your seeing damn near rail on both channels at the outputs?
  12. ivandezande
    1,941
    Twin Cities
    Yessir. But the outputs aren't shorted. I've had this happen when I put in a transistor backwards before but I dang sure I didn't this time.
  13. avionic
    46,297
    Fort Dodge, Iowa
    What voltages are you seeing around TR707 and 708?
  14. avionic
    46,297
    Fort Dodge, Iowa
    Don't sir me.. I work for a living.:D
    ivandezande likes this.
  15. ivandezande
    1,941
    Twin Cities
  16. avionic
    46,297
    Fort Dodge, Iowa
    + or - 37?
  17. ivandezande
    1,941
    Twin Cities
    Negative.
  18. avionic
    46,297
    Fort Dodge, Iowa
    -37 vdc is correct for the collectors of the LTP.
  19. avionic
    46,297
    Fort Dodge, Iowa
    What did you replace the TR 707 and 708 with? KSC1845?
  20. ivandezande
    1,941
    Twin Cities
    KSC2690
