saharajim
Hello all. I'm looking for some help with my CR-620 again. I repaired this receiver a couple of years ago and now it's needing some more work. A couple years back I replace TR722 a 2SB560 as I found it was shorted C to E. With help from AKer's. http://audiokarma.org/forums/index.php?threads/yamaha-cr620-repair-question.648377/
Well this time it blew the main 3 amp power supply fuse and TR722 has failed again and this time the outputs failed as well TR724 and TR726. I've replaced all three installed a new fuse and slowly powered it up using my variac and watching the current. The issue is it seams to power up fine and both channels are working however, even at very low output TR722 gets too hot to touch and I can smell it or something burning. I've checked over the rest of the transistors and they seam to be fine. Any suggestions on why this transistor is so hot and what to check is appreciated.
