Yamaha CR2020
Discussion in 'Yamaha' started by Jacob Carter, Apr 18, 2018.
  1. Jacob Carter
    Jacob Carter New Member
    5
    TL;DR CR2020 putting out no soumd through the roght side.
    Hey guys I wanted to see some opinions about what I should do about a problem. About a week ago I bought a cr2020 and it worked great up until a day or 2 ago. I was listening to a couple records and I heard a about 2 or 3 "pops", which I just assumed came from dust on the record or was just noise cause it was old. Then it popped again and I lost the whole right side of sound. I turned it to the radio and put an aux cable to it to see if it was my turntable, but it's not. Any ideas on what I should do?
  2. mhardy6647
    53,187
    no soumd from the roght side -- legt sode OK?
    ahem
    First and foremost: check (e.g., exercise) the main amp/preamp coupling switch.
    (probably best to do this with the receiver switched off)
    BTDT
  3. avionic
    45,611
    Fort Dodge, Iowa
    welcome to AK....After excersizing the coupler switch. Check your RCA jack connections.
  4. avionic
    45,611
    Fort Dodge, Iowa
    It could be a dirty switch or control. Fouled relay contacts. Or even cold solder connection(s).
  5. avionic
    45,611
    Fort Dodge, Iowa
    If you have a seperate pre-amp or something to use as a pre-amp. You can decouple the Pre-out/main-in. Hook the seperate pre-amp to the main-in jacks and listen . It will give me a better idea of which way to go.
  6. avionic
    45,611
    Fort Dodge, Iowa
    If you have a seperate power amp we can go the other way. Using the 2020 preamp to a seperate amp. Either way we can eliminate either the pre-amp or the power amps in the 2020.
  7. EKforReal
    EKforReal New Member
    22
    Welcome Jake. I told you there would be some fine folks who would take the time to help you out. Using separates is a great idea. If you wanna come over soon I’ve a pre and a power we can use to check it with.
    ETLS likes this.
  8. Jacob Carter
    5
    Alright I got deoxit to clean all my connections and I worked it into the switches, and now I get no sound at all. What should my next step be?
  9. avionic
    45,611
    Fort Dodge, Iowa
    Go over your switch settings and verify the coupler switch( rear panel) is in the coupled position.
  10. avionic
    45,611
    Fort Dodge, Iowa
    Are you hearing and relay "click" shortly after power on ?
  11. avionic
    45,611
    Fort Dodge, Iowa
    Did you try to verify with and seperate amp or pre-amp ?
  12. Jacob Carter
    5
    Haven't tried to verify with amp/pre-amp. But, I did run everything through my old receiver and there's nothing coming out of it either now, no sound on phono, tuner, aux. Even hooked up different speakers and still got nothing.
  13. avionic
    45,611
    Fort Dodge, Iowa
  14. Jacob Carter
    5
    I don't hear any click when I throw the power switch
  15. avionic
    45,611
    Fort Dodge, Iowa
    No "click"..Its in protect mode.;) Protect mode = no sound.
  16. avionic
    45,611
    Fort Dodge, Iowa
    How are you at following a schematic ? Do you have a multimeter ? Soldering tools ?
  17. avionic
    45,611
    Fort Dodge, Iowa
    On the power supply circiut board right behind the meters. There are two heatsinked " pass " transistors. Check there solder connections for ring cracks. Reflow there solder connections if in doubt.
  18. avionic
    45,611
    Fort Dodge, Iowa
    On the verticle electrolytic board.That the power supply board plugs into. There are > 4 resistors < 2 each 22Ω and 2 each 33Ω. These four are covered in the >Service bulletin.< Check there solder connections as well.
  19. avionic
    45,611
    Fort Dodge, Iowa
  20. Jacob Carter
    5
    Used the 2020 as a power amp and got nothing again, but then used it as the pre amp and it works, got sound. What's next?
