Yamaha CR640 tuning meters
i have a Yamaha receiver that tunes stations OK but the meters do not respond. Any ideas on what I could do to change this?
The signal strength meter deflects when tuning the dial then falls to zero on station. The centering meter moves some but always stays to the left of center.
Are you getting "stereo" indication with the LED's. Do the LED's appear to be functioning correctly ?
With power off does the tuning meter point to zero ?
There are a variety of adjustments that can be made without test equipment, but from your description those won't help. You need alignment and possibly troubleshooting. Where are you?
The center tuning meter adjustment usually does not require any test equipment. You usually tune to a quiet part on the dial(only white noise) and adjust the discriminator(quadrature or ratio detector) for a zero across the meter. You have to have the correct nylon tuning tool for the core that is used. be careful that these transformers have usually 2 cores, one for a zero and one for linearity. One usually adjust both of them. For linearity, one uses as IF sweeper to set "S"curve buty best method is to measure mono THD and adj for lowest THD.
The signal strength meter is adjusted with a set input RF level.
The signals to these meters usually go through switches, so they should be cleaned as well as part of a tuner tune up.
