recycler27
I have gotten some advice from avionic on the Yamaha M-4 power amplifier. I could not figure out how to send an attachment to him by PM, so I am posting in the DIY forum. I will probably reveal my incompetence and lack of understanding of electronics in the following, so I apologize in advance.
How can I safely and effectively bypass the two little variable resistors/potentiometers in the back of this amplifier? I suspect that the pots are worn or damaged; rather than try to find replacement parts, I want to remove them from the signal path. This is a fine vintage amp, so I want the modification to do no harm and be reversible.
I looked for information and advice online, then examined the circuit diagram and the actual configuration on the amp. Attached is my best guess for doing the bypass.
View attachment M-4 bypass volume pots.pdf
