Don't think I'll be standing on the woofer in bare feet to remove the magnet though.
I wrote some notes in case I need to do this again. Hope it helps someone:
- Measure the resistance of the voice coil. Mine was about 4.6 ohms which I believe is typical from what I've read.
- I first put painters tape over the holes in the back of the basket to stop anything from falling through onto the back of the speaker cone.
- Tap the existing hole in the top of the pole piece to 1/4 -20. It's tight, tap slowly, removing the tap often to let filings drop out. I got appox 1/2" depth.
- Screw the driver basket (4 mounting holes) to a 18" +- square piece of plywood with the tapped hole in the pole facing up. I used 3/4" plywood.
- Mark a vertical line on the basket, magnet, and pole so It can be reassembled in the same position. I read somewhere that it's important?
- Firmly tap thin putty knives between the pole piece and magnet until a small gap can be seen all around. Don't pry or it will chip the magnet. I did it. Then use larger and larger screwdrivers, shims, etc to get a 3/8" gap.
- Fasten a handle to the pole using a 1/4-20 bolt in the hole you tapped. I used a 18" piece of aluminum bar with a hole drilled in the middle to give good pulling power.
- Stand on the plywood and pull the pole piece from the magnet and basket.
- Remove the handle from the pole.
- Tap thin putty knives between the magnet and the basket until a small gap can be seen.
- Pull the magnet off the basket. It's not too strong a magnetic pull so I just grabbed it and pulled it off.
- Protect the voice coil by sliding thin plastic shims between it and the basket. I used a small plastic Pepsi bottle cut into pieces. Don't want to damage the coils while cleaning.
- Clean the mating surfaces of the basket, both sides of the magnet and the pole face.
- Remove the screws holding the basket to the plywood.
- Cut the dust cap off. I found this scary but once I finished it really wasn't too bad. Cut above the glue line on an angle and don't go deep. I tried cutting on the glue line and it didn't work. The cap is pretty tough paper so a sharp knife is needed.
- Center and epoxy the magnet back on the basket using the vertical alignment lines you put on at the beginning. I don't believe this has to be a perfect centering like when the pole is going to be installed later. I also used slow setting epoxy (gave me lots of time) and left it overnight. I put a thin layer about 1/4" wide around the outer edge only.
- To install the pole without damaging the voice coil is next.
- Drill a hole in the middle of the plywood (I made a recess for a bolt head) and bolt the pole to the plywood using a 1/4-20 bolt. I used washers between the pole and plywood to take up space.
- Clamp the plywood to a bench to hold it and the pole from moving.
- Remove the plastic shims protecting the voice coil if it's still installed.
- I did not apply epoxy to the mating surface of the pole and magnet. Slowly lower the basket with magnet attached onto the pole. Look down through the middle where the dust cap was and line it up carefully so that the pole goes into the middle of the voice coil tube. I was able to hold the basket until the pole was just starting into coil tube when the magnetic force pulled it quickly to the pole.
- Remove the bolt from the plywood.
- Place the jig over the magnet with the adjusting bolts resting on the top of the magnet and the bolts snug against the edge of the pole piece.
- Flip it over and adjust the bolts (pushing the pole around only) until the speaker cone moves freely in and out and there is no rubbing between the voice coil and the pole. Might need to remove some masking tape to let air in the back.
- Flip it back over and expoxy the edge of the pole to the magnet. Flip it back over and make sure nothing has moved. Again I used slow setting epoxy to give time for adjustment.
- Next day I removed the jig and epoxied where my jig was pushed on the pole to complete 100% of the circumference.
- I also added additional epoxy to the seam between the magnet and basket to reinforce this joint too.
- Glue the dust cap back on. I haven't actually done this yet. I need to purchase the proper glue to see if its thick enough. I don't want to have it run down the inside of the voice coil tube. I might need to purchase a new vented dust cap.
I also took some pictures if anyone is interested.
