Yamaha PC2002M restoration
Discussion in 'Yamaha' started by amr2, Apr 4, 2017.
  1. amr2
    amr2 Active Member
    442
    My latest pickup, an old PC2002M. It works, although it is in poor condition. I will disassembly it and restore it the best I can. The more difficult part to restore will be the meter and power switch plastic frames. If anyone have them (the plastic frames), please send me a PM…
    I will post some photos as project progresses.
  2. Sound Dragon
    Sound Dragon AK Subscriber Subscriber
    1,075
    Valley Stream. NY
    Looking forward to your upcoming Journey. I have two in my possession. Complete opposites in looks. One looks like it lost a fight with a gorilla and was patched up and the other looks like it just came out of the box.
  3. amr2
    amr2 Active Member
    442
    Yes, I've seen the pics..wow...
    on the other hand...Has anyone recapped this amp?
  4. rottalpha
    rottalpha Yamaholic Subscriber
    1,366
    Middle of Crook County
    Can't wait to see the progress.
    I am assuming that it will be similar quality as the 2602 you just did :)
  5. amr2
    amr2 Active Member
    442
    Thanks, I will try my best! ;)
    rottalpha likes this.
  6. Bert 1100
    Bert 1100 Super Member
    1,139
    Planquiri, Switzerland
  7. SoCal Sam
    SoCal Sam Lunatic Member
    17,102
    How is the DC offset on your example? I have four PC2002M's which do not come out of protection because DC offset is too high. Unfortunately, offset is controlled by DC Servo and is non-adjustable.
  8. rottalpha
    1,366
  9. rottalpha
    1,366
    I am no EE but common sense tels me that if the DC servo worked within specs once, it can be brought to the same spec onc emore.
    Are there any unobtanium components on this amp? I am thinking that carefully matching new components and replacing the entire servo section, should probably do it.
    It would be much easyer it it were adjustable. I am surprised that no EE looked into this issue and tried to solve the problem...maybe it is not so eary as just changing the components...
    I would be courious to see what AMR2 comes up with...he allways figures things out :bigok:
  10. SoCal Sam
    17,102
    I wish I was an EE. Here is what I know. My amps were from an amusement park and are very high hour. I was told they were from the Happiest Place on Earth but I cannot confirm that. Over time, the driver boards have become conductive which causes the DC Servo to set DC well over 1 Volt so no clicky. The DC Servo is not a module or a chip. I watched my tech (who is an EE) disable the DC Servo by lifting one of the two components of the DC Servo but I have forgotten which part it was.
  11. amr2
    amr2 Active Member
    442
    I don't know, I wil test it over the weekend.
    Sometimes DC offset drifting is due to bad solder joints, or a component out of specs.
    You can remove the servo and insert a good quality capacitor in the feedback loop as a last resort. :D
  12. souljay3
    souljay3 Active Member
    180
    adelaide oz
    I'll be following this thread closely,i joined the club a few weeks ago,all has been ok apart from the power switch breaking on mine,i was running it with a c50 pre but that started to run pretty hot so swapped it out for a marantz 3200 which was ok but decided to try a 1060 i have and thought that sounded better than the other 2,what are others using as pre's with theirs?
  13. rottalpha
    1,366
    :beerchug:
  14. amr2
    amr2 Active Member
    442
    The amp has arrived! It's no exactly clean...:rflmao:
    IMG_1438.JPG IMG_1439.JPG IMG_1440.JPG IMG_1441.JPG IMG_1442.JPG IMG_1443.JPG IMG_1444.JPG
    Mr. Yamaha, rottalpha and souljay3 like this.
  15. SoCal Sam
    17,102
    Missing covers?
  16. Oilmaster
    Oilmaster Drillers do it deeper Subscriber
    1,127
    Paris & The Hague
    220V !
    Where does it come from ?
  17. rottalpha
    1,366
    My guess would be Spain or from somewhere close by
  18. amr2
    amr2 Active Member
    442
    no, thank goodness...
  19. amr2
    amr2 Active Member
    442
    Yes! You're right.
  20. amr2
    amr2 Active Member
    442
    It seems to be OK, only a few mV.
