Yamaha R-2000
Discussion in 'Yamaha' started by Rex Runner, Apr 13, 2018.
  1. Rex Runner
    Rex Runner BANG THY HEAD THAT WILL NOT BANG Subscriber
    306
    Canton, Ohio
    Recent owner of a very nice Yamaha R-2000. Unlimited clean power. Nice. One issue. Ugly hum from phono section. Even without a table hooked up. Before I go digging. Any ideas?
  2. OMGCat!
    2,791
    El Sereno, CA
    Likely bad solder joint I'd bet. If you wiggle the connectors does it go away or change?
  3. Rex Runner
    306
    Canton, Ohio
    Hums without ANY connection
  4. avionic
    41,251
    Fort Dodge, Iowa
    Both channels ?
  5. avionic
    41,251
    Fort Dodge, Iowa
    If yes ---power source for the phono section ie dried out cap or broken solder connection in the power supply or to the phono circuit board.
    If no --- broken ground solder connection or a bad cap as well, for that channel.
  6. avionic
    41,251
    Fort Dodge, Iowa
    How loud is the noise ? Is it a hum or static type noise ?
  7. Rex Runner
    306
    Canton, Ohio
    Very audible hum
  8. avionic
    41,251
    Fort Dodge, Iowa
  9. Rex Runner
    306
    Canton, Ohio
    Yes. But I just noticed that the hum doesn't appear until receiver warms up. A bad cap does sound appropriate
  10. homebrew
    homebrew Active Member
    207
    If all else fails, try this.
  11. Rex Runner
    306
    Canton, Ohio
    Im sure a easy fix is in store. If all else fails a phono pre amp into aux. works. I was skeptical that a receiver boasting 150 WPC and not weighing 80 pounds. I stand corrected. Yamaha done good on this one. lots and lots and even more clean power. I like it
  12. avionic
    41,251
    Fort Dodge, Iowa
    Do you know your way around a schematic ? A couple things need to be checked.
  13. Rex Runner
    306
    Canton, Ohio
    I do. I havnt had time to open her up yet. Too many on going projects. The reason I asked originally was to see if this may have been a chronic issue with the R-2000
  14. avionic
    41,251
    Fort Dodge, Iowa
    I was just going to say. Check your +12 volt supply feeding the auto phono processor IC402 pin 14 when the machine is acting up.
  15. avionic
    41,251
    Fort Dodge, Iowa
    The 4558 opamp Vcc voltages as well IC401 pin 8.
  16. Rex Runner
    306
    Canton, Ohio
    That I will. The job is always easier accepting advice from someone who has already been there. Thank you
  17. avionic
    41,251
    Fort Dodge, Iowa
    That one 12v power source would mess up both channels.
  18. avionic
    41,251
    Fort Dodge, Iowa
    Any electrolytics connected to it are suspects as well.
  19. avionic
    41,251
    Fort Dodge, Iowa
    MC headamp and Phono Equalizer opamps
    + and - 16vcc going to opamps IC110. And the + and - 27vcc going to IC111 & 112.
  20. SoCal Sam
    SoCal Sam Lunatic Member
    17,878
    The R-1000 and R-2000 were so close to greatness. If only Yamaha had implemented a fully synthesized digital tuner that was as reliable and effective as say the Concept 12.0D, it would have been a winner. Hope you get your phono amp sorted.
