rocknroller
Have this amp with audio going into the power amp section, no fuses blown but no output either, and bad (low) rail voltage of like -2/2v coming off the Bridge rectifier D5FB20. Can't find an actual R-8 schematic but this is a R-9 and should be almost identical. Got about 33vac across the BE terminals from the transformer but 91vac across the Reds, where schematic says should be 61.7vac. Is the rectifier bad given it's only putting out 2vdc? Blown because the 91vac input? Both the transformer and Rectifier bad? Transformer just showing wrong readings because rectifier is bad?
