Yamaha Rx-900u delayed relay click
Discussion in 'Yamaha' started by Odizzieus, Aug 6, 2018.
  1. Odizzieus
    Odizzieus Member
    75
    When I turn on the receiver for the first time in a day, it takes about 15 minutes before the relay clicks. If I turn off the receiver for an hour or two, the relay still takes time to click. If I turn it off and then back on, it clicks in about 10 seconds
  2. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,436
    Fort Dodge, Iowa
    There is probably a small dried up capacitor in the protect circuit that's responsible for the RC time constant that establishes the delay time.
  3. avionic
    46,436
    Fort Dodge, Iowa
    Look for C190 220µf/6.3 vdc it should be located pretty close to the protect relay.
    rcs16 likes this.
  4. rcs16
    4,246
    Baldwin, Ontario, Canada
    This unit is fresh on my mind after I re-built an amp channel, I found it easy to work on, take the top and bottom covers off, flip so you have access to the bottom. The component layout is shown from the copper side. Leads are auto inserted, so they are kinked, need to be straighten out with the hot iron first. pre-tin first before I remove the solder. Even after you remove the solder, use some very small needle nose pliers to straighten the leads, then they fall out of the holes with no damage.
    Good luck, I hope it is that ecap.
  5. Odizzieus
    Odizzieus Member
    75
    My replacement resistor comes today. Before I blew it like an idiot, the unit still didn’t click after a few seconds
  6. rcs16
    4,246
    capacitor C190?
  7. Odizzieus
    Odizzieus Member
    75
    Yeah, I need to replace transistor q140 cause it’s fried, but after I fix that I’ll see what happens again
    Oh wait no, c190 didn’t blow. I blew a resistor.
  8. rcs16
    4,246
    You have two threads going for the same amp. This does not help to solve your problems.
  9. Odizzieus
    Odizzieus Member
    75
    I have two different problems, I already know what I need to replace to get the amp working again that’s not the issue, the issue is that the relay still doesn’t click shortly after startup. Is there anything else that can affect the timing
  10. rcs16
    4,246
    It might be the amp section that is causing this relay delayed turn-on issue. look at the voltages around Q148,149
  11. mbz
    mbz Super Member
    2,441
    Melbourne, Victoria
    Did you replace C190. As mentioned it is part of the timing for relay activation. It is a 6.3Vdc item, such low voltage caps generally have a
    bad history of failing. If the cap is leaking, it will "never" charge up. Next step would be to measure dc offset to confirm ok then look for other
    failed components in protection circuit.
  12. Odizzieus
    Odizzieus Member
    75
    C190 was replaced with no result
  13. mbz
    mbz Super Member
    2,441
    Melbourne, Victoria
    enerally, the two scenarios are,
    - excessive dc voltage on speaker line so protection circuit does
    not operate the speaker relay
    - failure (component/conncetion,,,) in the protection circuit.
    Measure dc voltage, black probe connected to GND/Chassis at both sides
    of R283, repeat for both sides of R284,285,286 as per pix
