Yamaha T-2 mini overhaul
Discussion in 'Yamaha' started by Mr. Yamaha, Sep 14, 2017.
  1. Mr. Yamaha
    Mr. Yamaha Not so much Yamaha lately... Subscriber
    863
    Amsterdam Area, The Netherlands
    My T-2 needed some work because the power switch was creating a loud pop through the speakers when turned on and when turned off. It seems to be the power switch.
    While I was in there, I saw some leaking caps with corroded legs, so I decided to give the T-2 a mini overhaul.
    Including:
    • Replacement of all caps (all Nichicon KZ, FG and ES).
    • Replacement of the 3 rectifier diodes.
    • Upgrade the power switch to a Triac solution.
    • Resolder all connections.
    • Replace the fuses.
    • Cleaning of the switches.
    So far I took out all boards which will be worked on and started with the caps.
    More updates soon!
  2. avionic
    40,716
    Fort Dodge, Iowa
    :lurk:
  3. avionic
    40,716
    Fort Dodge, Iowa
    Well,if you read it on the internet It must be true.:rolleyes:.Not very reliable...This gear is 30-35 years + old and still working. I'd say that they are very reliable.
  4. Mr. Yamaha
    863
    :p
    So, not preventive replacing those?
    And what about the 2SD476A's? Are they more reliable than the 2SD234's?
  5. avionic
    40,716
    Fort Dodge, Iowa
    When I rebuild burnt up channels in the M series amplifiers.Which I do quite a few of. It is not due to the diodes failing . But to shorted output transistors and uncontrolled B+/- stressing them to the point of failure .I've had way more zeners smoke than 1S1555's. Its just quicker for me to replace a pulled OEM diode with a new one with long leads, rather than try and fiddle with short stubby leads.That and personal piece of mind. Because of stressed circuitry. I know they have been subjected to voltages they weren't meant to be subjected to.
    SoundOfSound, mgkfifty and Mr. Yamaha like this.
  6. Mr. Yamaha
    863
    Made some progress this weekend. The main board and the upper digital board are done. I must say, I'm pretty happy with the looks of the Nichicon KZ / FG's.
    All 'lytic caps and the rectifiers are replaced, all solder joints are renewed and all components which were awry placed, are re seated. Afterwards the boards were cleaned.
  7. Oldsansui441
    1,601
    Victoria, Australia
    Very neat work :thumbsup:, that is one serious tuner, l have read good things about the T-2 but l have never heard one or seen the internals before. Looking forward to hearing how you think it sounds when you are done.
  8. Oilmaster
    Oilmaster Drillers go deeper Subscriber
    1,212
    Paris & The Hague
    Your kitchen seems as spotless as your PCbs ;)
    Mr. Yamaha likes this.
  9. llwhtt
    llwhtt Super Member
    1,365
    SoCal
    That's a very small cat!
    Mrv8q likes this.
  10. Oldsansui441
    1,601
    Victoria, Australia
    Haha, l was going to say the same thing, is the cat very small or is that a very large pcb. The cat looks like it is checking out one of the new large Nichicon UFG's :rolleyes:.
  11. llwhtt
    llwhtt Super Member
    1,365
    SoCal
    Mouse size cat for getting into mouse holes.
    Mr. Yamaha and Oldsansui441 like this.
  12. Oilmaster
    1,212
    Paris & The Hague
    And that why there is a dedicated thread "cats on audio gear" on AK
    miauw
  13. MannyE
    MannyE Exterminate! Subscriber
    4,739
    Miami Beach
    Beautiful work!
  14. Mr. Yamaha
    863
    Yeah, it really sounds great. Let's hope it still does (or better) when it's finished :biggrin:
    Best thread on AK!
    Thx!
  15. Oldsansui441
    1,601
    Victoria, Australia
    If it already sounded great it will be interesting to see what gains you have made.
  16. Mr. Yamaha
    863
    Finished this baby last weekend. She sings again. And no pop anymore when turned on or off. Due to the caps or due to the Triac switch? I guess we'll never know :idea:
  17. Mark B
    Mark B Yamaha Fan Subscriber
    5,371
    usa
  18. Oldsansui441
    1,601
    Victoria, Australia
    Very nice, looks great ;).
  19. 39cross
    39cross AK Subscriber Subscriber
    912
    Beverly, MA
    Are those rectifiers at the bottom of your photo of the replaced caps? or something else?
    I'd be curious to see a photo of how you wired the switch if you have one.
  20. Mr. Yamaha
    863
    Yes, those are the rectifiers. Sorry, I did not take a picture of the triac switch. I mounted it on the frame behind the transformer.
