1. Rest in Peace Paul (Kegger) If you would like to help the family in this time of great sorrow and need, you may donate on their GoFundme page: https://www.gofundme.com/mckechnie-medical-and-funeral-fund?
    Dismiss Notice
Yamaha T-33 schematic- ABANDONED
Discussion in 'Tuners' started by CT Jim, Mar 12, 2017.
  1. CT Jim
    CT Jim AK Subscriber Subscriber
    2,985
    Branford, CT. 06405
    Simple inexpensive tuner, but does not power up. Another Aker has one of these and uses it without the display, but this one won't even power up?
    I'd like to give it an hour before scrapping it!! Cannot find a SM or schematic, I think a model T-10 has the T-33 within it's manual?
  2. CT Jim
    2,985
    Branford, CT. 06405
    No one has a schematic? not worth putting a pot of money in it, but the challenge is always lurking in the background!!
  3. rcs16
    rcs16 Super Member
    2,738
    Baldwin, Ontario, Canada
    Did you check hifiengine? I did no lucky. Show a pic what is in it, if you scrap it, might be some parts to keep.
  4. CT Jim
    2,985
    Branford, CT. 06405
    I do check around, hifi engine and other places, but I don't want to buy a SM for $15 when if working I might get $20
  5. chazix
    chazix AK Subscriber Subscriber
    899
    Groton MA
    Well, heck, how much challenge would there be if you had the service manual? :)
    It's a virtual certainty that there will be one or more heat-sink-mounted semiconductors that serve as voltage regulators, so you might start by locating those, figuring out which pins are input and output, and seeing what voltages are on those pins.
    In what's probably the most likely example, the heat-sunk part will be a transistor, with its collector as the input and its emitter as the output.
    I'd best not try to elaborate much more without knowing whether I'm already way off base...
    Cheers,
    chazix
  6. rcs16
    rcs16 Super Member
    2,738
    A picture of the innards would certainly help. Could try/check the AC line fuse to start with :)
  7. CT Jim
    2,985
    Branford, CT. 06405
    Thank You for the obvious fuse suggestion....
    Having the service manual would provide a few places to check readings to narrow down where it doesn't get thru. I have no desire to spend hours screwin around with a $15 tuner, it's worth an hour to me, after that off to scrap and I'll continue with my regular power and speaker projects. I do hate to junk stuff, but parting it out doesn't seem very practical.
    Maybe I'll just put it in BT for parts, and move on.
