Yamaha T-85 Antenna
Discussion in 'Tuners' started by milo63, Jun 30, 2018.
  1. milo63
    milo63 “Talent is a pursued interest." Bob Ross Subscriber
    358
    Everett, WA
    I thought I had it figured out but I thought wrong...maybe.
    Is it the same as most of the Yamaha theater amps or a different animal?
    Matt
  2. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,428
    Fort Dodge, Iowa
    Most likely. AM/FM reception hasn't changed much.
  3. avionic
    46,428
    Fort Dodge, Iowa
    The better the external antenna the better the reception.
    darkblue94 and milo63 like this.
  4. musichal
    11,784
    Norman OK
    If you're talking about connectors, I think (not sure) some of the newer Yamahas have DIN antenna connectors and the T-85 likely acepts 300-ohm twin-lead and/or 75ohm coax connectors. But your post leaves out a lot. What are you trying to figure out?
    avionic and darkblue94 like this.
  5. avionic
    46,428
    Fort Dodge, Iowa
    Good points.
    musichal likes this.
  6. rcs16
    4,246
    Baldwin, Ontario, Canada
    The T-85 has one of those old school slide on DIN type RF connectors for FM. I drilled a hole beside it and added a "F" type connector. I just soldered a short piece of coax to the existing connector metal bits that run onto the pcb. It works fine.
    There is no 300 ohm balanced in this design.
    I have a RX-900U receiver as well, same crappy FM connector.
    The AM antenna looks like it is common to many other Yamaha units. My T-85 did not come with the AM loop antenna. I would have to check the service manuals to confirm what models used the same AM loop.
  7. I LIKE MUSIC
    I LIKE MUSIC Super Member
    Technically it is called a PAL or Belling-Lee type connector.
    Simple adapters are available to make it compatible with F-59 type connectors.
    I have a box of them somewhere.
  8. Blue Shadow
    22,241
    SE PA
    I use these on my TX-1000
  9. rcs16
    4,246
    I have tried above since it is the easiest to obtain. the problem is that the center pins is a smaller diameter (designed for a "F") than the PAL or Belling-Lee type connector center pin socket, so it is not a very good fit but is better than nothing.
