Hi guys.
This is my first visit here after recently discovering the vintage tuner site.:yes:
It appears the display lamps have failed on my trusty old TX900.
After a bit of research i read somewhere the lamps are 9.2 volt.
Can anyone confirm if this is correct, and will i be able to procure these lamps locally, [australia] with aftermarket lamps or do i need factory replacements?
While i have the hood up on this machine i sholud mention it also has intermittent operation of the left channel which is easily rectified by simply placing my hand firmly on the top center rear.
also touchimg the L/H output connector.
I am no electronic expert but can wield a solder gun with some success.
I suspect it could have a dry joint, not sure why i say this apart from having heard this expression . [swaping wires confirms fault is in L/H chanel]
Is this a likely explanation?:scratch2:
Any advice on how to replace the lamps also appreciated.
Thanks,
Tony.
Thanks,
Tony.
