EDIT NOT QUITE SOLVED: Issue with all three pots & pot adjustments but came back aaaagggghhhh
EDIT2: Was the diodes!!!
This wasn't holding speed so I cleaned the pots and put in all new electrolytic caps & transistors, and it still won't hold speed. But now, it pulses fairly aggressively as if I put in the wrong transistor somewhere. Yeah, the new parts seem to have made it run worse.
So I bet I messed something up somewhere. I double and triple checked my transistor pin orientations and they all appear correct three times over. So I'd love it if someone could verify that my parts list is correct, especially the transistors. Maybe I goofed with the wrong parts. Maybe I got my NPN and PNP wrong?
One thing that surprised me is the pin orientation of the KSA733YTA on the data sheet (E B C) so I had to install them basically vertically into the TR5 - TR9 and TR11 & TR12 spots. I trust the data sheet but thought I'd mention it. (Edit: Get center collector ones!)
Thanks in advance!
Power Circuit Board C103 470/50 Mouser 647-TVX1H471MCD
Power Circuit Board C101 470/35 Mouser 647-TVX1V471MCD
Power Circuit Board TR101 2SC789 Mouser 512-KSD526Y
Power Circuit Board TR102 2SC458 Mouser 512-KSC1815YTA
Servo Circuit Board TR1, TR2, TR3, TR4 2SD571(K) or (L) Mouser 512-KSD1616AYTA NO! THIS IS WRONG: USE 512-KSC1008CYTA INSTEAD
Servo Circuit Board TR5, TR6, TR7, TR8, TR9 2SA733(P) or (Q) Mouser 512-KSA733YTA: ORDER KSA733CYTA INSTEAD, THEY ARE CENTER COLLECTOR!
Servo Circuit Board TR10, T13 2SC945 (K) or (P) Mouser 512-KSC2383YTA
Servo Circuit Board TR11, TR12 2SA733K Mouser 512-KSA733YTA: ORDER KSA733CYTA INSTEAD, THEY ARE CENTER COLLECTOR!
I would also recommend replacing the trim pots - but I don't have the part #s ...
I didn't snap pics / videos yet but can add them to help diagnose.
Thanks in advance!
