DragonMaster
I've had loads of trouble with this amp so far... (noise, problems with meter calibration, DC in subsonic filter, pop, crackle, dirty selector causing dead inputs, won't turn on, hum, dead bulbs, missing screws, cigarette gunk everywhere, cold solder joints, etc.)
I fixed most of the problems over the last few years, but there's hum coming from the power amp (even if I disconnect the preamp and put a load on the power amp input, it hums in both channels -- the lower the impedance, the more hum there is)
I recently recapped the PSU board on the bottom (only the polarized electrolytics), which fixed problems, but that should be unrelated, since it's not supplying the power amps. However, the hum was intermittent before I recapped it, but it seems to be permanent now...
I doubt the problem is on the power amp boards, since both channels hum the same way.
