coronachris
Member
I am very happy with the MS-22B. I own a luxman c120a which is a well respected pre amp, it is in need of a recap and I don't have the time right now, and have wanted to venture into the world of tubes a bit so this seemed to be a good time. For a T.T. I run a Dual CS5000 w/ortofon OM20. Running through the Yaqin. To a Grant Fidelity TubeDAC 09 which is doing double duty as a pre amp. To a Luxman M120a Finally to a pair of Klipsch Heresy II's. To my ears so far it equals the luxman, which I think is pretty good for the price. I believe the gain is a bit lower than a SS which evidently common with tube pre amps. I notice it a little bit quieter, but nothing I'm worried about. I did upgrade the tubes to TJ full music tubes early on, which I had wanted to do. It sounds so good I'm having trouble finding the time to give the original tubes the proper break-in time for a fair comparison. Hopes this helps someone. Chris
