Binski99
I just got my Dynaco FM-3 , but their is one problem the power switch is broken.
How many amps should the switch I get be rated for?
I have already replaced the dial bulb with an LED using a 150 ohm resistor and a white led from radioshack. I did this because I could not get the original light to stay on even after resoldering it so I took it out and put the led in.
The led mod (Look behind the bluish green circle)
