Yay or Nay.....
Discussion in 'Tape' started by Natitude, Aug 10, 2018.
  1. Natitude
    Natitude Super Member
    4,426
    Hampton Roads, Va
    I’m wanting to add my first tape deck into my listening space. I don’t want nor can I afford to spend a lot on a deck. The question I have is, there’s a JVC TD-R431 I can pick up near me. I understand that this more than likely won’t be my last deck I buy, that being said.... Is that a decent deck to consider to start out with? My only pre-requisites is the deck be reliable and black to match the rest of my components......
  2. zedex
    zedex Active Member
    341
    BC
    I would pass. Its an auto reverse with a flipping head. I would buy a non auto reverse deck.
    Natitude likes this.
  3. kaplang
    kaplang Works for me ! Subscriber
    Get what you can afford. Something is better then nothing.
  4. 3db
    3db Active Member
    237
    Auto reverse decks do flip the heads when the direction of play/recording changes. The problem with this mechanism is head alignment. Head alignment is key for both playback and recording. Poor head alignment will give poor or very rolled off high frequency response, muffled or distant mids. Auto reverse decks may sound good in one direction and poor in the other. Thats why auto reverse decks are shunned upon. Try and stay away from auto reverse decks.
  5. Natitude
    4,426
    Hampton Roads, Va
    Makes sense. Not being familiar with it... is there a way to turn off auto reverse?....
  6. musichal
    11,806
    Norman OK
    Get a Nak RX-2 with UDAR, or higher up the UDAR chain if you can afford it.
  7. Bob
    Bob AK Subscriber Subscriber
    2,565
    West coast
    unless it's going to be the absolute last thing you buy, depending on the price and the value to you,
    buy it. you can always upgrade to some nirvana machine down the road.
    meanwhile, buy (CL, ebay, thrift shop) a cassette with music you know. bring it and headphones
    (hopefully ones you know the sound quality of) and listen to it. then buy or not.
    take it home and using qtips and alcohol or aficionado-approved-and-nakamichi-Revox-approved
    cleaning fluid, clean anything that moves (capstans, rollers, guides, heads, etc) and then
    enjoy the music. (I would suggest demagnetizing the heads but no one ever does this).
  8. 2N697
    2N697 New Member
    46
    SW Missouri
    Turning off the reverse won't really help much. All of the ones I have seen, (and owned), had the head mounted inside this little swiveling mount, and the mount develops a lot of play (movement) the same day you take it home from the store; the head moves "by design". After very little use, you have a head which is adjusted for an "average" of what alignment should be; best analogy I can think of is trying to align the steering on a car with a worn-out front end.
  9. Natitude
    4,426
    Hampton Roads, Va
    I can almost bet it won’t be the last one I buy, I’m sure it’s like the rest of the things in this addicting hobby:biggrin: I can get it for $25.... that’s why I think it wouldn’t be a bad one to at least start with....
  10. 3db
    3db Active Member
    237
    I have three Yamaha decks which I purchased used, two KX-800s ( I got for cheap but are rather pricey now on Ebay) and a KX630. The KX630 needed a head alignment which I got done and its now good. Naks are good decks but IHO, your paying for the name. I would look at decks from Yamaha, Teac, Pioneer, Technics, and Sony.
  11. Jonny Ramone
    Jonny Ramone Super Member
    1,894
    Save your money for something better.
  12. zedex
    zedex Active Member
    341
    BC
    25$ ?? I would buy it . :) Assuming its in excellent physical condition.
  13. BOUXY
    BOUXY Super Member
    4,682
    WPG,MB CANADA
    SONY????????????
  14. Natitude
    4,426
    Hampton Roads, Va
    It appears it is from the pics, but you know how that is sometimes. It comes with instruction book fwiw.....
  15. 3db
    3db Active Member
    237
  16. zedex
    zedex Active Member
    341
    BC
    Is that $25 all in? lol I cant find any specs on that deck . It might be BPC for all i know.
  17. Natitude
    4,426
    Hampton Roads, Va
  18. Natitude
    4,426
    Hampton Roads, Va
    Lol... yeah... all in, a whopping $25. I’ve had a hard time finding info too. This is about all I found....
  19. 2N697
    2N697 New Member
    46
    SW Missouri
    I suppose one could make the argument that spending 25 bucks now might save you money in the long run by helping you to decide what features are most important when you set out to purchase your "dream deck" in the future. If it really looks that good and works I would probably spring for it too. Lots more money than that gets wasted by me most every day without anything to show for it.
  20. zedex
    zedex Active Member
    341
    BC
    Its a nice looking deck. :) Worse case its a door stop. A Mcdonalds dinner is $25 and you feel like shit afterward monetarily and physically. :)
