eljefe3126
New Member
Greetings. I'm having a little difficulty with this and wondering if I'm doing something wrong. Hopefully, someone here can set me straight.
I'm trying to wring every last watt out of a pair of KT-88s. The project is a musical instrument amp, so distortion levels aren't critical (although I can't have crossover distortion, so class B is out). I'm considering going to Class AB2, but even if I stick with Class AB1, the question still stands.
The attached pic shows what I'm trying to do. The red line is the "Class A" loadline, with Vo at 800 Volts and Ipo biased to 43-44 mA. The other half of the push-pull pair cuts off and the active tube goes into "Class B" operation at about 468 Volts and 87 mA. Finally, the system peaks at about 35 Volts and 200 mA (Class AB1) or 0 Volts and 210 mA (Class AB2).
The green curve is constant plate dissipation at 42 Watts.
Now, from the blue "Class B" line, I get an impedance of 3800 Ohms. If my true impedance is 4x that, that seems absurdly high at 15,200 Ohms. To put that in perspective, the Marhall Major produces about 200 Watts from 4 KT-88s in ultralinear, with an output transformer of 2,250 Ohms, equivalent to 4,500 Oms for a single pair. The Hiwatt DR201 is in the same class, 200 Watts from 4 KT-88s in Pentode mode, from an output transformer at 2,200 Ohms, equivalent to 4,400 Ohms from a single pair. Hiwatt also made the DR405, which extracted something north of 300 Watts from 6 KT-88s, with the output transformer at 1,700 Ohms (equal to 5,100 Ohms for a single pair).
5,100 Ohms is a long way from 15,200 Ohms. Before I start winding a transformer, I want to be sure that I'm not committing some gross error.
There is also output power to deal with. I'm using P = (HT-Vmin) * Ipeak / 2, which in Class AB2 gives P = (800-0) * 0.210 /2 = 84 Watts. I should be somewhere north of 100 Watts for the pair, which is what the reference circuits in the GE manual show. Is that for one side only? If so, 168 Watts is really good news, as the Class B reference circuit generates 150 Watts into a 6,000 Ohm load "for speech only", and apparently something less into 7,500 Ohms "for other purposes".
In Class AB1, power should be P = (800-35)*0.200 = 76.5 Watts per tube, which would yield 153 Watts without the Class B crossover distortion, which would still be a good day.
Using P = 2 * (HT-50)^2 / Rload, I get 2 * (800-50)^2 / 3800 = 296 Watts, which seems wrong. I presume the 50 is an assumed Class AB1 peak at Va = 50 Volts, Ia = 0. If I double 3800 to 7600, I get 148 Watts, which seems reasonable.
I'm just looking for a sanity check here, thanks.
