Yet another record bin made from single 3/4" sheet
Discussion in 'DIY' started by Omegaman, Dec 3, 2016.
  1. Omegaman
    Omegaman Ultra Super Member
    2,954
    Scottsdale, Arizona
    Thanks to the good guys at AudioKarma I finally got around to making a record bin
    3/4" high grade plywood $50.00
    3/4" half round trim $7.00
    Tube of construction adhesive $2.78
    I have a pneumatic staple gun and I will also screw the whole thing together
    Here are the plans I used
    Here is my award winning wood craftsmen workshop aka carport
    Here are the cut pieces
    Questions:
    Should the lower shelf be raised off the floor? I have casters so perhaps the floor should be raised to conceal the casters?
    Where should I place the upper deck? Is there a standard position or do I just "wing it"
    Anti_Skate and djwhy60 like this.
  2. onwardjames
    16,697
    Kentucky
    Wow, rock on. Was actually headed to lowes to obtain the parts as well.
  3. Omegaman
    2,954
    Scottsdale, Arizona
    Here it is all put together
    I put the upper bin lower than expected but it will hold records fine
    Plenty strong with glue, pneumo--staples and wood screws
    Its on casters
    I am going to paint it brown
    All caulked tight
    I had to clamp some trim pieces
  4. onwardjames
    16,697
    Kentucky
    Splendid work. How many cuts did you have to make? Or did the big box store do it for you?
  5. Omegaman
    2,954
    Scottsdale, Arizona
    The big box store did the first four cuts but I would never allow them to do it again
    They use a rough cut blade, I use a high tooth count blade
    They really don't care about quality cuts or precision, I do
    Its a good thing caulking hides defects well
    I estimate it cost me a total of $150 with casters, trim, paint and whatnot
    I expect 2 quarts of paint should cover it with two coats
    Not counting labor which was about eight hours total
    I probably will make another
  6. Omegaman
    2,954
    Scottsdale, Arizona
    One quart did the job
    Oasis8, John James and jaybirdss396 like this.
  7. arts
    arts Super Member
    3,893
    Qc, Canada
    Very nice,well done!
  8. redk9258
    redk9258 AK Subscriber Subscriber
    1,660
    Illinois, close to St. Louis.
    Nice. Put the ones you play on top and your doubles / still sealed in the bottom so you don't have to break your back looking down there! LOL
  9. Omegaman
    2,954
    Scottsdale, Arizona
    Yeah, its kind of a failure
    I did ask the question in the first post but I was out in the workshop and didn't search the previous threads for the answer
    Oh well, it stores records okay
  10. onwardjames
    16,697
    Kentucky
    Failure?? Youre too hard on yourself, Don.
    Looks fantastic!
  11. Omegaman
    2,954
    Scottsdale, Arizona
    Here is the load test
    Lavane and tmtomh like this.
  12. squirrelnest
    squirrelnest Addicted Member
    7,474
    Alexandria, VA
    Looks real nice.....about how many albums can it hold?
  13. Omegaman
    2,954
    Scottsdale, Arizona
    Approximately 400
    tmtomh likes this.
  14. redk9258
    1,660
    I wish I had a place to put one or two of those. The only thing I might consider doing is making a small base for it to raise it slightly. Maybe even put a storage drawer for stuff (45s!). Most of my LPs are in a closet. I have 4 Peaches crates set on their side and stacked up- kinda like a shelf. I always wanted to build a Barrister bookcase but big enough for LPs. I haven't done any wood working for a long time and can't seem to get motivated to start a project like that.
  15. Omegaman
    2,954
    Scottsdale, Arizona
    I had 11 cardboard boxes of LP's
    I still have three
  16. psychoaudio
    psychoaudio I didn't do it Subscriber
    excellent DIY. Thank you for sharing the plans!
  17. Omegaman
    2,954
    Scottsdale, Arizona
    I didn't create the plans. I just utilized them, The were made available here on AudioKarma
    I also placed the upper deck too low and it makes it difficult to get to the lower records bins
    It works good enough to store them just not as easy to scan thru them
    but thanks, I tried
  18. seti
    seti MonkeyButtonPusher
    115
    Arcansas
    This is great I may follow your lead on this one. I HATE spine reading.
  19. arts
    arts Super Member
    3,893
    Qc, Canada
    I'm getting closer to starting mine. My entryway is now well stocked with Russian Birch plywood,as one of the local suppliers had a sale recently.......
  20. Lavane
    8,031
    northern cal.
    It wouldnt look bad with some legs on it if you dont like bending over so far. I book marked your thread. I like what ya did there! :thumbsup:
