Well it's been awhile since I have looked at this amp. What I would like to do is use the power transformer and output transformers and build them up as a RH84 version one. Kegger stated in one of his posts that the rh84 required 80 ma. I would like to add a tone stack from Max Robinson (fun with tubes).
My question are the photofacts for the 5B27 show the power transformer as 660vct, 75ma, 6.3 volts@2.1 amp and 5volt@2 amp. The original 5b27 runs 5y3, 2x el84, 12ax7 and 12au7. I would be keeping the 5y3 and el84s, 12ax7 and using a 12at7 instead of the 12au7. So, I Guess what I'm saying is if this PT ran the same tube lineup originally except for swapping 12au7 for 12at7 shouldn't it be ok current wise? Also, is it possibly rated too low on the photofacts sheet? One last thought for now is in would use a choke in place of resister between first and second cap on power supply and drop first cap from 40uf to 10uf. I appreciate any thought on this.
