There's an entire group of hams and SWL'ers who lovingly restore those models.
You might want to check Videokarma's Vintage TV & Radio forums.
You can also hit www.QRZ.com's forums and those for eHam.net, too.
Cheers,
David
The big stumbling block with T/Os is often the converter tube...a 1L6. The very definition of unobtanium. There ARE workarounds...putzy but usually worth it. If the bottom set has a good 1L6 inside its value has probably quintupled.
Thought you guys might want to check out the TO's lil brother. You still get the suction cups and detachable wave magnet antenna, but it's only AM. I'm thinking about giving it a go on some DXing. The dial now is set to KCMO in St. Louis.
These can kick some serious butt. I used to one one with an external antenna strung on the roof of the apartment house where I grew up. About 70' high with nothing higher surrounding us and about 125' long. Not even my Hallicrafters could keep up with it.
The antenna was good enough that it was easy to get into Boston to listen to the ball games using a crystal set; about 80 miles south. On a good night I remember picking up a Toronto AM station with the crystal set; subbed in the Zenith and it was like the station was next door and listened to some great music; them were the good old days before they start screwing with AM broadcasting.
I am probably wrong but, I was always of the opinion Zenith engineering in the radio department was some of the best.
