Zero cost improvement to speaker performance!
Discussion in 'Speakers' started by MonoMania, Sep 12, 2017.
  1. MonoMania
    MonoMania New Member
    25
    Canada
    Almost too obvious to mention, but sometimes the obvious is overlooked:
    Periodically tighten (don't over-tighten) any screws on the exterior of the cabinet!
    I rebuilt a pair a few years back, listened to them on a regular basis, but never gave them much thought after I set them on their stands. Gradually I was finding them less satisfying, noticing muddiness in the bass, poorer soundstaging, etc, but hadn't gotten around to investigating...
    It wasn't until a rattle developed on certain bass notes that the lightbulb went on.
    Every screw had been fully tightened a couple years ago, but between the vibration of the cabinet and the expansion/contraction from temperature every single screw on the driver baskets and the rear connector panel had loosened by at least a half-turn, allowing some air to escape around the caulking.
    After re-tightening, everything snapped right back into focus: sound staging back, bass no longer muddy!
    From now on I'll be remembering to include this in my maintenance routine!
    *Of course, not all speakers will have this problem with fasteners, but mine did.
    *Be careful not to over-tighten screws, to avoid bending baskets or warping plastic parts.
    Hopefully someone out there will find this useful.
    John James, asilker and Wildcat like this.
  2. MonoMania
    25
    Canada
    Feel free to add your own "Zero Cost" and/or "Ridiculously Obvious" speaker tips to this thread!
    asilker likes this.
  3. MurrayLives
    MurrayLives Born to lose, live to win Subscriber
    534
    Philadelphia
    Get your woofers closer to the floor for better bass. Aim your tweeters over your head to elevate the soundstage.
    asilker likes this.
  4. jberger
    jberger AK Subscriber Subscriber
    1,812
    Long Beach, CA
    When stripping speaker wires, leave the positive wire (or marked conductor) approximately 1.5" longer on each end than the negative wire. That way, you'll always know how to get your wiring in phase without looking for the stripe/marking/insulation color.
    This also has the benefit of reducing the chance of shorting the speaker wires, since the tips are farther apart and less likely to touch.
    The 3" difference in wire length is negligible.
    stish, gdmoore28, fishondwan and 4 others like this.
  5. gizzyman47
    gizzyman47 Super Member
    1,158
    utah
    Get speakers out of corners (unless made to perform there). Also, move them out into the room some. Let them breath. If you move them out from the wall, keep the distance from the side walls a different distance than the wall behind the speakers.
    E.Man and MonoMania like this.
  6. tyeeslayer
    tyeeslayer Super Member
    3,146
    Abbotsford, British Columbia
    Increase volume.
    Spitfirejoe, CLB3, malden and 4 others like this.
  7. audiosignal
    audiosignal Active Member
    118
    Flipping the woofers 180 degrees to reverse sagging.
    gdmoore28, asilker and MonoMania like this.
  8. MonoMania
    25
    Canada
    Never heard or thought of that... Makes sense though! How often do you do it? Yearly?
  9. audiosignal
    118
    Yearly would be good, in theory. However, considering risk of stripping the mdf / wood, I'll just do once every 5-10yrs or when refurbishing.
  10. dcmfan
    dcmfan AK Subscriber Subscriber
    3,698
    Dallas, TX
    Listen at night. After the rest of the family is in bed and the house is quiet.
  11. scoloheros
    scoloheros Active Member
    354
    It's not quite "0" cost, but all it took was some glue. I found a pair of speakers that sounded blown, there was a rattle at higher volume. It was only the baffle that had come unglued, some glue along the outer edge is all it took to fix it.
  12. toddalin
    toddalin Super Member
    1,997
    In some cases, remove the grill/cloth while listening. Not suggested with kids and/or pets.
    MonoMania likes this.
  13. toddalin
    1,997
    If you wear glasses, remove them while listening. They create a diffraction pattern about your head.
    Also if possible, listen in the dark or at least close your eyes. The removal of other "cues" will heighten your perception of hearing and expand the soundstage.
  14. darkblue94
    darkblue94 It wasn't me. Subscriber
    6,754
    Beaverton, Oregon
    Clean your ear canals every once in a while.
    CLB3, stish, MonoMania and 1 other person like this.
  15. Poultrygeist
    Poultrygeist Addicted Member
  16. Poultrygeist
    Some drivers improve in SQ with a dust cap circumcision. This Eminence Beta 12LTA is a prime example.
  17. Poultrygeist
    The famous "98 Cent Tweak" consists of placing polyfill behind a whizzer cone. After rolling it in your hands wrap it around the whizzer underside and it should stay in place. Cleans up upper midrange honk.
  18. GD70
    GD70 AK Subscriber Subscriber
    12,643
    Northern Westchester Co, NY
    If your cabs are a nice wood veneer, oil them once a year. Keeps the wood glowing!
  19. jberger
    1,812
    Long Beach, CA
    Turn all of the lights off and listen in complete darkness.
  20. jberger
    1,812
    Long Beach, CA
    Hot water and alcohol in a WaterPik on low power setting (using a separate pick, obviously).
    darkblue94 likes this.
