gjposner
Well-Known Member
I have recently added a pair of Spica TC-50's to my living room which sit atop my everyday speakers (heavily modded CV LS-12's which includes new tweeters, crossover matrix, and custom wound VC on woofer for impedance matching). Previously I had been moving the speaker wire, but having just finished a re-finishing a Bell-O stand that needed love, I figured it was time to make this right. The Receiver is an onkyo Tx-NR 809
Without doing much research, I figured, sure, Zone 2 should work. While Zone 2 does function, it does not output to either of my subs (a pair of BIC F-12's needed for the large space). So my first thought to solve this was to use the pre-outs and while it does work, there is no volume control, so that option is out. The Spicas do need at least one of the BIC's as they lack quite a bit in the low end.
A suggestion came in to run the speaker cables through the BIC's and while I could do that for a single spica and a single sub, the second spica is 10ft from the first sub and almost 35 from the second (the second BIC sits between 2 couches in an L shape).
I then was suggested to take a look at speaker selectors and really, the electronics geek in me went WTF?!?!? Protection circuits use a big ass resistor as a way of detecting over current.. It was also suggested that I look into one with impedance matching, but I am not sure what that means electronically. I am concerned it may add unwanted noise into the system.
If it can be something simple, like a switch box, I would prefer to build it myself and realistically any switchbox that I buy I will be modifying to have Bananas and match the rack that I use currently. The Spicas measure a high 20.6 ohms resting with the CV's at 9.6 ohms. Even if they were ran simultaneously the amp would not care as I believe the 809 is good down to 2 ohms so part of me wonders if I need the protection or the impedance matching or if I can build my own box with nice toggles and such?
Does anyone have a wiring diagram for switch boxes? Ones with and without the fancy protection and impedance matching? Trying to figure out what to do. Any help would be great!
TL;DR: trying to find the best way to use my subs with a zone 2 speaker set, be it through fancy wiring or a custom switchbox. Help?
