This thread documents the conversion of a pair of Utility Large Advent speakers to accept a waveguide, a Selenium driver and associated crossover.
The EconoWaveguide project is extensively documented in this thread:
http://audiokarma.org/forums/showthread.php?t=150939
It is up to 180 pages as of this writing. I decided to document this particular conversion in another thread because it is intended to be a guide for others who wish to do this conversion, and in the time it would take to glean the info out of 180 pages of posts, you could just about build a pair of anything.
Note that I am not 'supporting' this project. I'm going to put everything useful that I know about this into this thread. If you PM me and ask for advice about this or similar projects I'll probably point you back to this thread.
I chose the Utility Large Advent speaker for conversion for the following reasons:
They're common and inexpensive. Just about anyone should be able to find and afford a pair.
It's a full range unit with plenty of deep bass, a very important consideration for me.
Relatively easy to drive.
Large enough to be easy to work on.
Decent, heavy cabinet that doesn't need bracing and has room for the waveguide
To my ear, the tweeter is the weak point of this unit so it's a natural for upgrading
The parts:
One pair of Utility Large Advent
cabinets. Other Advent cabinets will work, but the New LA with the rounded 'bullnose' edge is too narrow as is.
One pair of Advent
woofers in good condition. I used the metal basket woofers because they're not a flaming pain to re-foam like the Masonite ones. The Masonite woofer will apparently perform very similarly to these Jensen-made drivers.
One pair of
waveguides, Pyle type PH612.
One pair of 8 Ohm
compression drivers, Selenium type D210Ti. The model 220 is said to be equivalent for this purpose. I chose the 210 because they were under $25 each at the time, which is a screaming bargain for a quality compression driver.
Note that as of 12/08 our preferred parts source for these drivers, Parts Express is no longer showing the 210 driver in the catalog. They are showing the 220 driver as a 'replacement' for the 210. We think this means that the low cost driver option is being phased out.
EDIT
The D210Ti is now out of production. Builders should seek out the D220Ti instead. This project applies to both, but the 220 has certain technical advantages.
The PH612 waveguide used in this project is now available from Parts Express, which also stocks the D220Ti driver and all of the crossover components.
END EDIT
CROSSOVERS
One pair of ZILCHLAB EconoWave crossover boards. These were built out with the basic 'low sensitivity woofer' version of the parts complement.
Please see the main thread for extensive discussion of the crossover.
(Crossover)
http://audiokarma.org/forums/showpost.php?p=2281446&postcount=2529
If you use the JACKLAB EconoWave crossover boards, please consider the phasing of the woofer and horn carefully. The documentation for the boards provides guidance on this issue.
A note on the crossover parts. The most expensive part of the crossover is the 1.5mh woofer choke. I just pulled the woofer choke out of one of my ULA speakers & measured it. It measured approx. 1.58mh. That could easily be used in place of the 1.5mh if necessary. It has slightly smaller wire and would have higher DCR, but that's really not a major issue here.
An inductor of slightly higher inductance than required can frequently be 'unwound' a few turns to reduce it to the required value. An inductance bridge or LCR meter is required for this to work properly.
If like me you have tons of caps and resistors around, and you get lucky and find inductors in the range of 1.4mh - 1.6mh in your Advents, then you could get away with scratch building your crossovers with only the purchase of the LPads and the .6mh inductors.
I scrap out a lot of vintage speakers. I always preserve the Lpads and inductors and I have re-used them in the past for new projects. I'll keep the caps from an old crossover if they're film and of decent size. Old NP electrolytics always get tossed.
About 2 lbs of fiberglass to fill each cabinet.
2 pairs speaker binding posts, some Masonite for terminal panels, misc. wire, connectors, etc.
I built mine with fuses and 1/4" TRS input jacks to accomodate loaning them to musician friends.
The finished speaker is shown below:
