Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #61
Old 11-03-2009, 04:20 PM
Russellc's Avatar
Russellc Russellc is offline
AK Member
I have used the "Light bulb variac" when I built my P-P 6550 tube amp.
It worked very well. When first switched on, the lightbulb glowed brightly, then if all is well, dims down.....if not, it glows brighter. Worked like a charm, I had unintentionally reversed the leads from the outputs, which made the amp highly unstable. That, and the bias meters swinging wildly let me know
before anything went up in flames!
russellc
__________________
AR The TurntableW/Scillia/Merrill Mods/Unitrac
AVA Superpas III, Counterpoint SA1000
Mcintosh Mc225, Homebrew P-P 6550, JBL 6230,
Mitsubishi DA-A15 DC
Altec A7, Aria5, Microns, Econowave#4,(JBL 4647w/2235H),Indignias(#25&26)
MR 67, FM-3 ,Mitsubishi DA-F10, Rotel 971
  #62
Old 11-03-2009, 08:56 PM
westend's Avatar
westend westend is offline
AK Subscriber
Quote:
Originally Posted by Russellc View Post
Whoops, I see you have already been there and that advice may be in question, sounds like maybe they have it backwards? I have the daniels boards, so I need to find out....
Russellc
Russell,
I put a meter on the trimmers before installing them, like I do for most of the components. I didn't want any surprises about values and have the mission of sorting out a mislocation, etc.. I measured that they were at the highest resistance. After placing them in circuit and prior to start-up, I metered them again and second guessed myself into believing I had them set wrong. A lot of this confusion was reading stuff that is passed along in the original DIY thread.
Here is a copy of the Datasheet of the 3296 Bourns trimmer which was supplied by Tech-DIY. NP commented that there is no difference in the method of mounting but I followed SpecialI's and Tal's orientation.
I am posting this up here so others don't get confused and have that heart-stopping moment when the amp is fed full current.
  #63
Old 11-03-2009, 09:14 PM
specialidiot's Avatar
specialidiot specialidiot is offline
a special kind of idiot..
Quote:
Originally Posted by westend View Post
Russell,
I triple measured every resistor before soldering them in place. Although I was an electronic tech doing board level troubleshooting in a previous life, I have learned that I no longer have the patience, or the knack for it.
You'll find that the pots are three-legged, with the resistance between the opposite legs the total value of the pot. Turning the screw varies the resistance between the center leg and the outside ones (duh). You'll find that two adjoining pads that the legs solder to are shorted at the pcb level. So you just have to figure that the value that matters is between the other two pads.
Yeah, clear as mud right?
Lance if you decide to go with an engraver to do an F5 logo, please let me know. I'd do mine as well.
It sure sounds nice tonight, how about yours?
__________________
Up: Transcendent Sound GG, Pass F5 diy, Yamaha PX-3 w/Dyna 10x5,Sony XDR-F1HD, Indignia
Down: Yamaha C-2x, B-2, T-1, AH! Njoe Tjoeb 4000, Cambridge Audio Azur 540C v2, Denon DP-62L w/DL-160,Diatone DS-77HRX, Cornwall II
Projects: KLH 17 Rebuild, Yamaha CR-1020
, Pass DIY F5
  #64
Old 11-04-2009, 12:32 AM
westend's Avatar
AK Subscriber
Jeff, I'm definitely thinking about the etching, machining, laser of an "F5" into the faceplate. It my hunt bears fruit, I'll let you know and we can double up. I haven't had time to hook it up, lol, been too busy metal working.
Old Fragger kinda' reminded me I should get busy on the faceplate so I'll show how far I got tonight. I could probably have had it to a mirror finish except for lack of sandpaper. I bossed the mounting bolt holes, chamfered all the holes on the drill press, and cut the edge chamfer on the router table. The handles will be cut down to match the faceplate height. I had to include a pic of the router table (I'm just really pleased how that turned out). It has saved a lot of time around here.
I promise I'll set up the F5, tomorrow, and report back what my impressions are *practices glowing adjectives in sleep*.
  #65
Old 11-04-2009, 01:06 AM
thefragger's Avatar
thefragger thefragger is offline
Certified Crazy.
Very nice looking! I tend to paint all my stuff, it's just easier
Almost there!
If the faceplate is aluminum, maybe you could find a local (read: small) cabinetmaker or sign manufacturer with a CNC getup to mill out what you want?
__________________
Quote:
Originally Posted by thefragger
I just don't get it, this amp was fine before I put it under the knife
Join the GTA / Toronto AKers Group!
Audiokarma
  #66
Old 11-04-2009, 01:27 AM
westend's Avatar
AK Subscriber
Quote:
Almost there!
I was thinking about painting almost all of the chassis pieces but after you get done sanding and cleaning, you still need to use an acid etching primer and then sand, paint, sand, paint, and probably a third coat, sand, paint, and finish wet sand. I added it all up and it seemed easier to just sand and polish. I guess if I want the aluminum tarnish-free, I'll have to anodize it or cover it with laquer. I could skip all that and take it to Jeff's powder-coating people but where's the fun in that?
The etching or machining is kind of a sticking point. None of the places that use a CNC setup want to break their rhythm to take on a little deal like this. They want to punch out as many parts as possible to make the machine earn it's keep. I do have "one card to play" and I'm weighing the choice of playing it.
  #67
Old 11-04-2009, 02:09 AM
thefragger's Avatar
Certified Crazy.
Yea... it can be tough to find a small shop with the gear and the ability to do a one-off. A neighbour of mine runs a custom cabinetry business (his garage is a thing of beauty) and he's usually busy, but has no problems doing one-off deals when he gets slow.
I'd say ask around and try to figure out when slow-season is (there always is one), then approach them in that window to see if they'll do it for yah. You may be waiting a while, though.
__________________
  #68
Old 11-04-2009, 08:59 AM
Russellc's Avatar
AK Member
Making it even muddier, I have the daniels boards, and apparently some believe there is a difference in that hookup between the daniels board and cviller boards. I guess I should ask Peter for clarification on this. I'm going to (eventually) fire up with my variac, so I should have slightly more warning if something is a miss.
Russellc
__________________
  #69
Old 11-04-2009, 01:21 PM
Russellc's Avatar
AK Member
Got a response over on DIY from Peter. He said as far as he remembered,
clockwise reduced the bias. He said he fires them up with the pot in its half way position, and has no trouble.
Russellc
__________________
  #70
Old 11-04-2009, 02:34 PM
golana's Avatar
golana golana is offline
analoG
There are companies on line that do this etch/ingraving all day long. I know about this from guitar amps face plates. Shipping a simple plate back and forth should be relatively cheap. Here's one, I'll just need to keep my eyes open for a few nights. http://www.amplates.com/faceplates.html
Audiokarma
  #71
Old 11-04-2009, 08:13 PM
MrIgotNomoney's Avatar
MrIgotNomoney MrIgotNomoney is offline
AK Member
Guys
Good info about the pot orientation, I have got my boards and and I am starting to plan out my build.
The biggest hassle is getting heatsinks and a chassis together, Im thinking to save money the best bet is to build my own chassis. Im still reeling over the cost and shipping for a pair of Conrad heatsinks.
I have a bunch of Nichicon 10000uf@50v I was thinking about using 10k uf and going with a 600va transformer for the ps. anyone using CVillers rectifier boards ?
The small parts and silicon, are pretty reasonable from TechDiy
bob
  #72
Old 11-04-2009, 08:27 PM
Quote:
I like squidward's idea of repurposing an old amp chassis and heatsinks. It would have to be a pretty big one - for the heatsinks anyway.
In an earlier discussion which might even be in this thread, some of us agreed that buying a block rectifier for a few bucks is well worth it compared to having to assemble multiple parts. You may save a buck or two, but the opportunity for failure is greater and its far less work to use the block.
__________________
, Pass DIY F5
  #73
Old 11-04-2009, 09:01 PM
AK Member
Specialidiot
I was thinking the same thing, the boards make for quite a few failure areas. I loke the block rectifiers reliable and easy to mount. Can use push on terminals too.
Cheeper after you figure in the diodes and heatsinks.
bob
  #74
Old 11-04-2009, 09:15 PM
cbrworm cbrworm is offline
AK Member
I can verify the Pdaniels boards clockwise lowers bias, CC raises bias.
Either way, when I fired mine up the first time I had voltmeters on both .47 ohm resistors and used a 100 watt bulb in series. They should start out as 0 volts with no bias and increase to .590ish as you turn the pots counter clockwise. I removed the bulb once I saw the bias come up to about .100 on both sides successfully
__________________
DD:SX-1250,GX-270D-SS,Sony TC-K850ES,Onkyo DX-C206,Numark TT,GFA-555ii,HTPC,DEQ2496,RSIIIa
HT:Onkyo TX-SR805,ZA SR71,DIYMA12,HTPC
OOS:SX-1010, SX-1050, GX-270D-SS(#2), GX-280D-SS, GX-255,Technics SL-1800, Nak CD-6,INF QLS5,RS4001, Beta20, Seas LOKI
  #75
Old 11-04-2009, 09:42 PM
Squidward's Avatar
Squidward Squidward is offline
Registered Squid
Ebay seller johnango is the guy who runs Antek, the torroid transformer place. Looks like he's also selling heatsinks for cheap now, too. Might be worth checking it out.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
MCM Electronics
Politicalchat.org
Videokarma.org
