Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 11-02-2009, 07:49 PM
Rey1 Rey1 is offline
AK Member
Elac Miracord 46 info
Hi,
I just picked up said turntable and, unlike my Dual, I cannot find much info on it. Can anyone tell me how to remove the platter? Also, I'd like to clean and lube it. Any recommendations on the type of lube? Anywhere I can find a diagram of where to put it? I did this with my Dual, but there is a lot of information on the web concerning what to use and where to apply. Not so with the Elac
  #2
Old 11-02-2009, 08:18 PM
Nat Nat is offline
AK Member
Have you checked Vinyl Engine for the manual -- they very well might have it.
  #3
Old 11-02-2009, 08:45 PM
larryderouin's Avatar
larryderouin larryderouin is offline
AK Member
I've got 2 10"F"'s for FISHER Consoles and a 50H. Almost got an 660 yday.
To answer your questions.
1. Take off the Rubber platter cover. Insert index fingers (1 each) into the holes on either side of the spindle. Put thumb on spindle, PUSH DOWN with THUMB, Pull UP with fingers. It will POP OFF! Be Careful It weighs about 6 pounds.
2.) 3 in 1 MOTOR OIL. Or Go to a Sewing machine center and get Sewing Machine Oil. For the Platter bearing (you have to dis-assemble underneath) use Lithium Grease. Mix oil into it 1 part oil 4-5 parts grease.
3.) Vinylengine.com has the 50H Manuals in German. Most of them are similar enough that you can use most any of the "Miracord" manuals with minor modifications to your technique. They don't go to much into lubrication but I'd say, if it has lube or grease on it, then clean off the old stuff and renew. Use oil for oil and lithium grease for the original.
Larry
__________________
Corpsman UP!!
Stick yer arm out...it won't hurt me a bit!!!
PIONEER FISHER SANSUI AKAI TEAC Magnavox Olympic Motorola DUAL Garrard. TMTL!
  #4
Old 11-02-2009, 08:46 PM
AK Member
Yes I did, The closest they get is info on the 50h, and that's all in German
  #5
Old 11-02-2009, 09:05 PM
AK Member
Larry,
Thanks, I got the platter off and the Idler wheel looks like new. I did check out the 50h service manual, but I didn't notice anything about the lube (my high school German is kaput though). however, I'll check it out again tomorrow.
Audiokarma
  #6
Old 11-02-2009, 09:23 PM
AK Member
Heavy Sucker ain't it!!! The green pain reminds me of Zinc Chromate Primer. Hmmmmm.
Try one of the higher numbered Miracords in English. None of them go too much into lubrication. Like I said earlier they are similar enough that you can use most any of the manuals wth minor modifications.
Larry
__________________
Corpsman UP!!
  #7
Old 11-02-2009, 10:14 PM
AK Member
Larry
Yeah,
It does weigh a ton. Seems very well built. Any suggestions about how to disassemble the platter bearing?
Rick
  #8
Old 11-03-2009, 10:43 AM
AK Member
I did a breakdown on the 10F a couple week ago and posted here. http://www.audiokarma.org/forums/sho...0&postcount=28
I compared my 50H to the 10F. Mechanically they are identical. The 46 should be also or very very close.
Larry
__________________
Corpsman UP!!
  #9
Old 11-03-2009, 04:30 PM
AK Member
Thanks Larry,
I'll have a look at it this weekend.
Rick
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
MCM Electronics
Politicalchat.org
Videokarma.org
