Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 01:46 AM
JohnLocke88 JohnLocke88 is offline
AK Member
Three Channel Organ Amp - NEED HELP
Hello everyone. I recently purchased a three channel organ amplifier on eBay. From my initial research, I have tentatively concluded that it is a Baldwin amplifier. I want to try to use it to drive some music speakers (probably vintage Polk Audio Monitor 7s or 10s.
The tube complement is (8) 6BQ5/EL84's, (3) 12AX7/ECC83's and (2) 5U4 rectifier tubes. (Included are the (2) 5U4 rect tubes; As such I will need the remaining (11). Any suggestions on brands? I saw some cheap NOS Russian stuff on eBay; this a good bet?
Also, If anyone knows anything else about this amp, I'd appreciate all the help/information you can offer.
http://i763.photobucket.com/albums/x...88/Baldwin.jpg
Video of another one (I think the same one) playing: http://video.google.com/videoplay?do...7468922418947#
  #2
Old 11-03-2009, 01:04 PM
Goodwill_HiFi's Avatar
Goodwill_HiFi Goodwill_HiFi is offline
AK Member
I have a similar amp, if not the same, sitting on my storage shelf in the basement. I got it off of Craigslist. I'd like to get it going at some point. I know next to nothing about tube equipment....... those light bulb thingies get hot right?
  #3
Old 11-03-2009, 03:00 PM
djnagle's Avatar
djnagle djnagle is offline
AK Member
I wonder where the other two OTs are???
__________________
I'm like a Super Hero with no powers or motivation
  #4
Old 11-03-2009, 03:25 PM
PatA's Avatar
PatA PatA is offline
AK Member
What is the potential of these amps in a home audio application? I'm assuming mono output only?
  #5
Old 11-03-2009, 03:30 PM
archie2's Avatar
archie2 archie2 is offline
AK Member
That might have driven the organ bass only. Dunno. I don't see three OPTs.
__________________
Yamaha CR 2020, Sansui 4000, Marantz 2220B, Marantz 4270
Sansui 8080DB, Carver 6200
Pilot 240, Magnavox 8802, Altec Lansing 345A
Boston Acoustics A150
Polk 10A
Spica TC-60
NHT SuperZeros
Wharfedale W70E
Audiokarma
  #6
Old 11-03-2009, 04:51 PM
cademan cademan is offline
AK Member
Quote:
A friend of mine has that exact same amp! There are two identical output transformers under the chassis!
Also, I believe it is a 4 channel amp. Two 6BQ5's per OPT on PP.
  #7
Old 11-03-2009, 05:14 PM
GordonW's Avatar
GordonW GordonW is offline
Speakerfixer
Last one of those I saw, IIRC, was three channel. Four 6BQ5s on the big OPT on the left rear of the chassis (PPP), and two 6BQ5 each on the two transformers under the chassis.
Regards,
Gordon.
__________________
Audio Atlanta- AK Site Sponsor www.audioatlanta.com
"It's the guys who think that attending meetings is real day's work that are the problem."- HepcatWilly
  #8
Old 11-03-2009, 10:51 PM
AK Member
Quote:
Originally Posted by GordonW View Post
Last one of those I saw, IIRC, was three channel. Four 6BQ5s on the big OPT on the left rear of the chassis (PPP), and two 6BQ5 each on the two transformers under the chassis. Regards,
Gordon.
You're probably correct as I was not able to study my friends up close, but he did show me the underside and the two hidden transformers.
  #9
Old 11-04-2009, 04:52 PM
AK Member
Upon further discussion with seller, looks like there is only one input, and three outputs; There are two trans on the bottom for the "weaker" channels.
Does anyone know if it is possible to modify this to accept two/three discrete channels of input?
  #10
Old 11-04-2009, 05:04 PM
AK Member
If you are tech savvy, you could probably see where each signal inputs to each of the 12AX7 tubes and split the inputs from there. Although I do not have the unit in front of me, I believe each 12AX7 tube drives each perspective channel individually.
EDIT: Pin #2 on each 12AX7 is the input. They are probably tied together from the single input so you could probably seperate them from there.
Audiokarma
  #11
Old 11-04-2009, 05:17 PM
AK Member
Awesome; I am not super tech savvy, but I can learn. I have the personality that if something is possible, I'll figure it out.
Knowing that it is physically possible is the key
  #12
Old 11-04-2009, 11:25 PM
AK Member
I just took a quick look at mine...... it's a single plug, but it has 5 possible conductors. I didn't look at the underside.
  #13
Old 11-05-2009, 12:40 AM
hatrack71's Avatar
hatrack71 hatrack71 is offline
AK Member
Are all three output trannys the same? Perhaps throwing a potentiometer volume control on the channel with four 6bq5s and attenuating it down to match is the answer.
__________________
Main Rig: Audio Electronic Supply AE-3, Dynakit Mark III's, Thorens TD-160, California Audio Labs Sigma, Altec Valencias, Tice Solo, EAR 834p
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
MCM Electronics
Politicalchat.org
Videokarma.org
