Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Audio Discussion
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 02:59 PM
Kenwoody53's Avatar
Kenwoody53 Kenwoody53 is offline
AK Member
Another Ground question please.
I didnt want to add this to other ground thread and get off topic for those who started them. I searched ground threads and not sure I answered my question. More like confused myself because I am not very technical on electronics, I just buy, plug in and play. Please give your idea, or lead me to the correct thread that may already answer this, I would appreciate it.
I have a Kenwood KRV 7060 with a Kenwood M2A and a M2 amp. I run two TT,s connected to a Rek O Kut switch. The receiver does not have a grounded plug nor does any of my equipment. The amps both have a ground lug on the back of them that is not utilized for now. I have no hum, noise or any problems. Should I leave well enough alone or should this be properly grounded somehow. If so, how?
  #2
Old 11-03-2009, 03:02 PM
Jon_Logan's Avatar
Jon_Logan Jon_Logan is offline
AK Member
Well enough alone. It's fine the way it is unless you want to play it in the rain.
  #3
Old 11-03-2009, 03:09 PM
Hi-FiGuy's Avatar
Hi-FiGuy Hi-FiGuy is offline
Vintage Electronics Sales
I agree with Jon, but the rule I've heard is to leave everything ungrounded except for the pre-amp. Ideally there is only one ground.
__________________
Engineers do it till it Hertz.
  #4
Old 11-03-2009, 04:07 PM
skazi skazi is offline
AK Member
Interesting, the diagram in my C1 preamp manual depicts a single wire running from the turntable to the ground lug on the preamp, and that's it. But, now that I read the description, it says to actually ground it for maximum safety and minimal interference.
So, if you just run a ground wire from the turntable to the ground lug on the preamp, and nothing after that, is it a pointless exercise?
Why do turntables use this when other components do not?
__________________
Main: Kenwood M1/C1/T1, Sony SCD-CD595, Energy RC Minis & Grado SR125
Computer: Motherboard -> HRT MusicStreamer -> Accurian -> Pioneer S-HF31-LR
  #5
Old 11-03-2009, 04:18 PM
secondslc's Avatar
secondslc secondslc is offline
mmmmmarantz
Do you know what makes 3 wire "better?"
http://www.audiokarma.org/forums/sho...d.php?t=202099
post 10....13...28
I would advise going with what he says.
Or post 3
http://www.audiokarma.org/forums/sho....php?p=1637762
Im an approvals engineer that works with industrial versions of UL and worldwide electrical codes. Any time you start modifying a unit, all liability is on you as to whether it catches your house on fire, electrocutes someone, or fails in any other way.
These things were designed to be safe from the factory. Unless there are tired components inside (old capacitors), or the cords are frayed, there is no reason to believe that these units are no longer safe.
__________________
Marantz PM-94,CD-94,CDA-94,ST-64, imperial 9s, and lots more.
Audiokarma
  #6
Old 11-03-2009, 04:45 PM
Jon_Logan's Avatar
AK Member
For improved safety, install a GFCI outlet where you plug in. In the event there are divergent currents, namely though somebody's body, the outlet will open.
  #7
Old 11-04-2009, 01:38 AM
Kenwoody53's Avatar
AK Member
Thanks a million for the info! The GFCI is a good idea. I have to use them at work and have personally seen them work, but thats an entire different story : ).
  #8
Old 11-04-2009, 01:44 AM
Hi-FiGuy's Avatar
Everything grounds to the pre-amp chassis, the pre-amp grounds to earth ground.
__________________
  #9
Old 11-04-2009, 06:16 PM
Suzuki Suzuki is offline
I trust my ears
I agree with Mr.Hi-FiGUY thoroughly.
__________________
Amp:6BM8/PP CDP:Sylvania DACboard:unknown SP:JVC (acoustic sus) EQ/divider:BEHRINGER Sub-woofer:JBL(J216Pro) Sub-woofer driver:Luxman
  #10
Old 11-04-2009, 06:24 PM
Cactus Bob's Avatar
Cactus Bob Cactus Bob is offline
It's A Life!
Quote:
Sorry to break in but . . . should the power amp be grounded to the preamp and the preamp is grounded by means of power cord or?
I ask this because my Pioneer Spec 2 amp make a little static noise now & then after it's running a while. Thanks Bob
__________________
Music First, Then Gear, Then People!
Technically, I'm not a guitar player, all I play is truth and emotion. — Jimi Hendrix
Audiokarma
  #11
Old 11-06-2009, 02:28 AM
Hi-FiGuy's Avatar
Everything grounds to the Pre-Amp chassis, the Pre-Amp is the only device that is grounded to earth would be the Pre-Amp, either through a grounded outlet (via power cable) or a copper rod pounded into the ground (If you don't have grounded outlets or your house was never grounded).
__________________
  #12
Old 11-06-2009, 03:43 AM
EchoWars's Avatar
EchoWars EchoWars is offline
Lee Ho Fook's or Bust
Adding an earth ground to consumer hi-fi gear that was sold with a two-prong plug is asking for trouble. And hum. There needs to be only one signal return for all devices connected to a receiver or preamp, and as soon as you tie any piece of gear to earth ground, you have added another highly undesirable path. It's that simple.
If you want to do it, just go do it then. But when it ends up sounding like the inside of your microwave, at least you'll know why. At the very least, you'll raise the noise floor. At worst, it'll sound like you spliced a two-prong plug to your speakers and stuck it in the wall.
I have no intention of debating this issue, since this is probably the 60th or 70th thread on the subject in the last couple of years. Everyone has said their piece, and hopefully you're intelligent enough to gather the facts and decide for yourself.
__________________
"We
Of the night
Will know
Many things
Of which
You sleepers
Have never
Dreamed" --Bessie Haley
  #13
Old 11-06-2009, 07:52 AM
whoaru99's Avatar
whoaru99 whoaru99 is offline
AK Member
Number one rule for something like this is...if it ain't broke, DON'T fix it.
__________________
push back against dubious claims that defy logic;
be on the lookout for misrepresentations;
question the lack of science when belief is the substitution;
be very skeptical when the denial of the laws of physics comes into play.
--jpaik
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
MCM Electronics
Politicalchat.org
Videokarma.org
