dfs824
Greetings, all - I am working on restoring my uncle's Pioneer RT-1011L reel-to-reel, and I have it working well, except for the "control lever" that regulates the power to the capstan. (First off, I don't know what this lever is actually called for which to search for parts - it's the one the tape threads under and then up to the take-up reel).
The switch inside works fine, but the problem is that the copper spring inside the unit to stop the lever has lost its tension over the years, and the lever easily falls past the notch and keeps the capstan and spindles running - sometimes uninterrupted, causing absolute mayhem with the tape spinning endlessly at a very high speed, whipping the tape end all over the place. As it stands right now, we can't leave the machine unattended near the end of the tape.
I have tried adjusting the copper spring with a pliers myself, but I haven't been able to get it right. I'd be much more comfortable replacing it with a fresh spring. Any help with the name of this assembly and the part itself would be appreciated, as well as suggestions on a source to obtain one.
Thank you,
Dan Sorce
Thank you,
Dan Sorce
