Here are some pix. I cut the circuit board out, there was really nothing you could get at with it still in the chassis, and the little white tags remind me which wire connects where. I am going to end up replacing all of the resistors and caps, so this is really going to be a full resto. I'm concerned about the transformers (this thing was out in the rain and snow for many years), but I'm going to take my chances with them for now. They've been drying out indoors for the last six months, hopefully it will work out. Amazingly, the tubes all tested good.
First, a resistor question: some of the resistors are larger (1/2 watt? 1 watt?) and some are smaller (1/4 watt? 1/2 watt?). I have some new replacements for the larger ones, but in the smaller size (I sound like such a newb!) Is it safe to replace larger with smaller? I can be patient and just buy the right ones, but if I already have them...
Next, capacitors: It looks based on the schematic, that those little un-labeled cans are 20 uF, even though they are significantly smaller than the 20uF cap that I have in the power supply. I figure I should just get all caps rated at 450V, since as Jon pointed out the highest voltage is 315. I'm not going to force myself to get bumble bees since they are very expensive, they can be switched in later if we need to. Can I use ceramic discs, or some NOS mica caps I have, as long as the rating is right? I have a whole drawer full of those old domino looking caps, would I be hurting anything if I use them instead of bumble bees? Please be patient, I am new to this. I understand that the tone might not be exactly what the old Gibson had, but would I be hurting anything electrically? BTW, the larger bumble bees are .047, the smaller ones .0047. I'm still trying to work out what the big white Cornell Dubilier cap is on the resistor side, it says its a 25uF but that doesn't show up on the schematic at all. And I'm still missing three caps that I can't quite account for.
Help!
P.S. I like the way the box is coming out. It's going to look great wrapped in vinyl or tweed.
