macman007
Mcintosh..Made In USA
Turned my 2125 on today and went to turn it off and now the power knob go's round and round, both directions but stays on all the time.
All power guard lights are out . I'm sure its on the vertical board behind the PG, lights the 2 caps (which ones, what values?) and the 2 - 1n4004 diodes (correct me if i'm wrong) The bulbs are good.
On power up, you never hear a relay click on and on power off you can hear the caps "draining down as the music quiets" if the source is still playing, leading me to believe the relay is stuck on all the time.
I think the relay contacts are welded together? I haven't open'd her up to see, pending the reply's I get here. If so how/ why? Is the relay on top of the board or bottom? I'm sure I can download a schematic if I don't already have one, But if anyone has picture that would be better.
I will take pictures to document step by step what I do and post to the thread the steps and issues I run into, to help others, depending on possible cost. I may just leave it alone for now if too expensive.
The unit plays well other than these 3 issues..the Power guard lights have been out since I got it, along with the relay issue. Now I want to fix them, along with the power switch issue since I have some time. Could I un-weld the relay points and burnish the points? I am running on a tight (almost non exixtant budget as I am out of work and looking for a job in the Auto industry as a mechanic, and times are tough. I should have saved some dough and bought a few less McIntosh pieces and I would have a nice sack$ to fall back on..kidding....
no regrets here, when the money's good it's good.
BTW, I don't hear the relay click on/off when I use the speaker switch either. Right now it stay's plugged in all the time on a selectable power cleaner/ supply, so I can control on/off from there. That way it isnt on 24/7.
This amp is in bridged mode, running a MC center channel with no other problems. It will run in stereo fine as well.
Thanks for any help, :thmbsp:
Phil
no regrets here, when the money's good it's good.BTW, I don't hear the relay click on/off when I use the speaker switch either. Right now it stay's plugged in all the time on a selectable power cleaner/ supply, so I can control on/off from there. That way it isnt on 24/7.
Phil
