Speaker/cabinet sealer
klsva
Recently refoamed my advents.Is there any type of sealer i can pick up at home depot to seal the cabinets,or do i need to order specific cabinet sealer from audio store??
I used Loctite Power Grab construction adhesive on my RSIIb cabinets. It's easy to smooth into the joints with a finger and dries rock-hard without cracking (unless you put it on an inch thick!).
You really need to clarify what you are trying to seal...... the cabinet parts to each other, or the drivers to the cabinet. You've got an answer for each scenario, so far.
for interior seams, I've always used '25 year' silicone caulk . . .
for the woofer opening, you definitely want something non-permanent - weatherstripping works, but you could just use what they used back in the day - plumbers putty :yes:
just make sure to clean both mating surfaces, and if you really want to go crazy, use T-nuts to mount the woofer, instead of the original wood screws . .
And there is another answer if they want to seal the wood veneer.
Yikes! I'm talking about sealing the inside seams of the cabinets where the panels meet! Do NOT use construction adhesive to seal the woofers to the cabinet, unless you want them to stay there forever!
For seam sealing and driver sealing, I favor 3M Black Strip Caulk. Sticks to damn near anything, easily worked and non-hardening. It comes in boxes of 60 12" long strips about 1/8" thick and 3/16" wide, which can be rolled thinner or rolled together as desired.
Not sure you need to go this far but the very best caulking compound used in construction is Vulkem 921 or 911 it is a Urethane type compound and the stickest **** I've ever tried to get off anything save baby ****. I been using it while residing my house with Hardie Plank (cement board) and its ability to adhear to a joint is amazing. Be sure to have a roll of TP to pickup or try to wipe up any mess. A wet finger makes a good smoothing tool. It akes 4 days to be dry but never gets hard always a little flex so it should be real good for seams in cabinets.
