tlcasper
Hello all.
I picked up a G-7700 that's been in storage for some time. Ascetically it's almost mint, just beautiful wood and metal. The one small issue with the exterior is that one of the push buttons has some of the chrome finish worn off. Does anyone know of way to repair this? I'm going to try a craft store, but if someone already has experience with this I would love to hear about it. I have looked on eBay, for a replacement. But only saw the complete set for $40.
Now for the bigger issue. With this beauty hooked up to speakers, the left channel sounds like angels singing. The right channel.... not so much . No sound at all until about 10% to 20%, then it pops in, not as loud as the left, but close. And very heavy static, almost a buzzing with the music. This is the same through the headphones.
I think my skill level is about novice. I've always been interested in electronics, but no real training or schooling. I follow instructions well and I am always willing to learn.
Here's what I've done so far;
read about 4 hours worth of posts here on this model and similar issues. Lots of good info, thanks to all who have contributed.
I have worked DeOxit into all pots and buttons. Repeating it 3 different times on the volume and balance.
I have done the DC offset, and the good channel was around 38mV, and I got it down to 6mV. The bad channel was over 1000mV and bouncing around continually. As soon as the screwdriver touches the pot the value drops significantly, I can get down to bellow 10mV, but it still bounces around a lot, and slowly climbs up into the 50mV to 70mV range, and always bouncing around.
I would like to check the bias, but after a crazy amount of time, I just can't find the points that the service manual wants me to check. Any help would be appreciated. I have added a photo of the board to the bottom of this post, the photo is borrowed from jugulator's thread about his G-7700. Thanks. Mine has no issue with the protection relay.
From the post I've read, and what I've learned on another repair, my best guess at this time is a bad or shorted output transistor. I have a Pioneer SX-3800, that had a lot of static on one channel, not as bad as this, but all the way through the volume. After much reading the most obvious was a shorted output transistors. It seams this model was known for cracked clips that attach the wiring to the transistors. Sure enough mine had cracked clips, replacement clips and a few minutes of time had the receiver tip top again. Many thanks.
The output transistors on the G-7700 seem to be soldered, not clips.
I'm not sure how to test the transistors, can this be done where they are, or do they need to be removed? Or is it obvious that one or more transistors has a short or gone bad, and I just need to replace them?
So, am I on the right path?
Any help would be greatly appreciated, I really want to bring this work of art back to life.
Dave
Dave
