PeterTuffin
Member
Last year I bought an AU 7700 from e-Bay. It has been wonderful, such a good sounding amp. Then the other day when I switched it on I heard a little buzz coming from inside and then it came on and played all day. Next day, no buzz but also no sound.
Today I opened it up. I'm not a very experienced fixer of electronics but with the guidance of a very nice book by Michael Jay Geier on fixing everything electronic I saw that one of the 2 fuses on the PCB had blown. I replaced it and the other one blew. Not very encouraging. As usual , a blown fuse means something else is wrong, typically a short. So I went down the circuit one stop away from the the fuses and saw 4 diodes. Anyway, I tested the 4 diodes and Yes! one of them is shorting.
Since it took me ages to disassemble the whole thing I decided to test a bit more, so I nominated two transistors for the job and I think managed to prove at least that they were not shorting anywhere. By the way, these were the first diodes and transistors I have ever tested, so I'm feeling quite chuffed that I actually found one that seems flaky!
Anyway, back to the real question: the flaky diode has IR4F (or maybe 1R4F) on it, and that's all. A quick search of my usual electronics shop's web site (in South Africa they're not called Radio Shack, they are Yebo Electronics) and then googling the whole world, I didn't find anything like a diode called IR4F.
I guess I'll take it in to Yebo and see if they can give me any advice, but maybe one of you AK good people will know how I can get one. I have attached a picture where you can see the two fuses and 3 good diodes and a space (just to the right of the big blue capacitor (which seems new)) where the bad diode is to be replaced.
