Opened the unit up and started taking voltage readings. I'm using the service manual schematics to find the proper voltages, but i have ran into a different voltage supply than what is stated on the schematics pcb F-2492 shows supply voltage of +15(pin 14) and -15(pin 17) to pin 15 ground. My readings show +29.2 VDC and -29.7 VDC, anyone know if the schematic is wrong or if its supposed to be 15 VDC? The left meter shows input levels when selected to show input level, but when you change the selector to show output level no meter movement. Using my meter on the mV setting i can follow the signal to this pcb with both channels showing input but when i check the outward bound signals from the pcb to the reed switch i only have the right. Thats why i'm concerned with the supply voltage being correct. I plan on using a scope to track the signal later tonight.
