vigman
SUBSCRIBER
You know when the doctor comes & says I have good news & bad news…
PRO's
Packed well.
No cockroach eggs.
It WORKED straight out of the box ( almost ) the unit sat for a LONG time…
The pots & switches were all a bit CRUNCHY. But just working em got signal to pass.
Meters work ( put my LED's in already ) .
It's fairly clean internally.
The main board has had all the feed thru's done.
SOME recapping done on main board.
I NOW have a use for the US power transformer!
Con's
Every connector has been de pinned and wires soldered to main male pins.
Someone decided it would be better instead of dealing with the feed thru's on the filter board just to re do the top traces in " trouble area's " with wire. ( not to bad of a job ).
Back panel is pretty rusted for the input jacks. more cosmetic then non functional… just OOOGGLLLYYY.
1 VERY bulgy cao in the main PS board.
Lacks bottom end.
The Tomorrow plan
Add multi voltage power transformer.
Replace main board caps.
Make the PS adjustments.
Remove front panel Wash, clean detail.
Spray all switches & pots.
Then see what the deal is…
I need to make a parts order for the BA-3K might as just add all of this to it.
PRO's
Packed well.
No cockroach eggs.
Con's
Lacks bottom end.
The Tomorrow plan
