Sansui_Boy
Hello guys,
the protection light on my amp wasn't working when i received it and after a good look at the internals i found that the board where the protection light is , is snapped clean in half:tears: the amp still works fine and it takes about 5 seconds for the relay to click. BTW the model is a AU D907F Extra it is exactly the same as the AU D11 but has a few revisions etc.
For the repair i thought about using a non conductive epoxy and using it to glue the boards together and using some jumper wire to connect the traces and also solder the cracked traces. I think this is a good idea but i am welcome for more ideas
Thanks
Photos: BTW the board is very small and is hard to be seen in the photo if you can see it the board says 'indicator' on it and in the middle of the board there is a straight crack between the two soldered leads
Thanks
