Well, first time i have seen one for sale locally and the timing was right so i pulled the trigger and bought it!
Was in rough shape, but after 6 hours of cleaning it looks pretty good!
I bought it knowing that it was in protection mode, after i cleaned it all up i hooked it up and yes it has the flashing protection light.
The good thing is i have the receiver section up and running using another power amp and it sounds pretty good!
Only issue i have found is when i hit the tone switch i lose a couple db from the right channel otherwise everything else runs as it should.
All switches were cleaned with deoxit so no more scratcheyness.....
Power amp was really dirty inside, was found in a barn and the person who had it did not have a clue what it was and gave it away for free (not to me though, this is the story from the guy i bought it from and i surely did not get it for close to free).
Anyways the power amp fuses are all good and none are blown, no burnt boards etc, just filthy.
I gave it a good cleaning and it is still in protection, also the power led is out.
Any ideas where i should look to see if this could possibly be an easy fix?
Locally there is a good tech but they only do full restorations and the previous owner was quoted $800.00+ for that over the phone.
I would like to get it up and running and if needed i well have it restored.
By the way, as you know everyone knows these are big! Well untill you actually see one in person you'll still look at it and say WOW, that receiver is huge!
Oh, this is a longshot but i need a left side attachment bracket as it did not come with it.
Thanks in advance!
Mike.
:thmbsp:
Thanks in advance!
Mike.
:thmbsp:
