MarkMeyer
On a couple of boards in my under-repair (plus total recap) AU-9500, there are several transistors where the leads have turned black over time.
Specifically, three boards that are like that are the F-2006 equalizer board, and the two F-2029 driver boards.
Black leads on components are generally an indication of overheating, but neither the transistor bodies themselves nor the entire remainder of the board or it's components show any sign at all of toasting.
Other than the black transistor leads, the boards could pass as brand new condition (visually).
As a general question; if these transistors test good, am I better off leaving them on the board?... or should I plan on replacing them, having to go through all the usual time consuming investigations trying to find a proper substititute?
TIA
TIA
