My Sansui 9090DB and Pioneer SX-828 that's two TOTL's
OK, here it is (although not much to see)! What you are looking at is my Apparatus Room (aka cupboard - or closet in American ) where all the central stuff sits. Bottom of rack is a Behringer Ultralink above an XLR panel, just for buffering / balancing / audio distribution.
However, there is a problem. The cat5 cabling radiates so much hash that it swamps the tuner's front end. (No, it's not the wireless AP that's to blame, surprisingly.)
I have taken certain steps to make the tuner more EMC compliant (1800pF across output terminals, removing ferrite rod, modifying case to class 1 (i.e. grounded via mains input).
But the cause, alas, is the UTP cable loom, which I think I'm going to have to replace with cat6 or shielded. (Disconnecting everything from - or depowering - the ethernet switch silences all interference, resulting in blissfully quiet stereo reception from the external antenna at the other end of the house.
